"Creader"
Old Apr 20, 2006 | 05:48 AM
4G63 T's Avatar
"Creader"
Is it detrimental to leave it hooked up all the time, will it affect ecu
function?
Thanks.
Old Apr 20, 2006 | 04:07 PM
4G63 T's Avatar
bump
Old Apr 20, 2006 | 04:11 PM
fromWRXtoEVO's Avatar
function?
Thanks.
I am not trying to sounds stupid but could you elaborate more on the word "creader"?, English is not my first language.
Thanks!!
Carlos
Old Apr 20, 2006 | 04:15 PM
4G63 T's Avatar
Its actually simple scan tool for obd 2...it does read and delete code
im throwing cel all the time so i decided to leave it hooked.
Old Apr 20, 2006 | 04:18 PM
Thanks, now I know what you mean. I have seen many different ones. Again, thanks for teaching me a "new" word, I am trying to learn as much english as I can .
I have seen some very basic methods such as high/ low beep nosies from a DMM and also regular voltage reading to indicate and decode the engine code.
I am assuming the creader word comes from Code reader uh?
Carlos
Old Apr 20, 2006 | 04:24 PM
4G63 T's Avatar
Hey, Carlos me too english is not my primary language...
but i learn this word from evo m too...
Old Apr 20, 2006 | 04:28 PM
puckadog's Avatar
creader is the product name. and yes you can leave it plugged in... it reads trouble codes and deletes them with no input from you.
Old Apr 21, 2006 | 06:00 AM
4G63 T's Avatar
thanks man..
btw im in carroll county
Old Apr 21, 2006 | 07:15 AM
kipper215's Avatar
the problem is thoe, what if somethingis really wrong and the think deletes the code so you don't see it. could be a potential problem.
Old Apr 21, 2006 | 07:45 AM
puckadog's Avatar
thanks man..
maybe i'll see you at the event at university of maryland in college park... i forget the date, i'll have to check.
Old Apr 21, 2006 | 04:10 PM
4G63 T's Avatar
You have point...
what i do..i disconnect it once in while then check code
if still po300.
Old May 19, 2006 | 01:41 AM
vboy425's Avatar
damn i have bought one from ebay and it doesn't work WTF ?? all it does is " Launch, - - - -, and E. i got the same one as every one else made by launch . i got an 04 evo
http://cgi.ebay.com/ebaymotors/CREAD...temZ4638827735
Old May 19, 2006 | 04:57 AM
puckadog's Avatar
when the engine isn't running, it will got through the 1 - 2 - 3 then E. when the engine is running, it should go through the numbers and end with all dashes ----. if it isn't doing that, then the reader is probably one of the ones that has problems reading the evo's ecu. i know vishnu had some problems with some the earlier creaders.
Old May 19, 2006 | 09:35 AM
vboy425's Avatar
my does goes through teh dash, but after teh dashes it goes E. i'm going to give it another try and will report back. WTF
Old May 19, 2006 | 09:48 AM
puckadog's Avatar
check w/dustin @vishnu and he can tell you from where the logo is on the unit if it is one of the ones that won't work with the evo.
