Mr tranny and clutch help
Old Mar 27, 2007 | 07:07 PM
Spinsall4's Avatar
Ok so about a week ago i went to the track and ever since then i have been smelling clutch. I have an 05 MR with the 6spd. Ever since going to the track which was about 500 miles ago no matter how i drive the car i smell clutch. I have noticed that every time i push the clutch in for 3rd gear the car will free rev about 1000 more rpms then where i try to shift. I have an ACT put in by Turbo Trix and the clutch has about 4000 miles on. The clutch release really high higher then stock and everytime i drive it i smell clutch. Its almost like the clutch isnt disengaged that is what is giving the clutch smell. The car only has trouble shift just in the morning when its cold. It shifts fine otherwise.TT put redline in the car i have heard good and bad thing about redline. Im not sure what it is and what i can do. If anyone can help me please do. Ive tried researching and seeing if there are any similar cases and cant find any. Please let me know if anyone can help.
Should i drain the redline out? and if so do i put GM syncomesh in or put OEM fluid back in. Please any help is great.
Old Mar 27, 2007 | 09:29 PM
lightspeed1's Avatar
It sounds like your clutch is not properly adjusted.....FWIW
Old Mar 27, 2007 | 10:50 PM
MR_EVO21's Avatar
Here is a link that will help with the clutch feel.
http://evomoto.com/tech_info.php?tec...b6409d4d506c0d
Also this one should help also.
http://evomoto.com/tech_info.php?tPa...90f9570c80cbe6
I hope this works for you bro. Also the first link will help you adjust your clutch pedal so it will engage properly. Good luck
Old Mar 28, 2007 | 06:03 AM
94AWDcoupe's Avatar
If clutch is releasing very high then it might be slipping all the time. That would account for the smell.
Old Mar 28, 2007 | 11:30 AM
Spinsall4's Avatar
Thanks for the help guy I will adjust it today and see if the smell goes away? any recomendation on fluid. Im pretty sure TT put redline in it when they did the clutch. any ideas should i just stay with that or drain and put new fluid in it. I have heard Shep recommends Redline MT90
Old Mar 28, 2007 | 07:31 PM
TurbotrixRacing's Avatar
Bring the car by and I will check the adjustment for you. We put Redline MT90 in all the EVO transmissions we do.
Keith
Old Mar 28, 2007 | 07:39 PM
Spinsall4's Avatar
Thanks kieth when can i bring it buy are u around fri? cani bring up fri sometime and have u check it out. Im in need of some help thanks man.
