Turbotrix Transmission Services
Old Oct 19, 2007 | 07:55 AM
TurbotrixRacing's Avatar
Hey Guys,
Here is a list of transmission/transfer case upgrades that we offer:
Basic Rebuild with TSB updates. $850
-new 2nd-5th gear synchros
-new 1-2 slider
-new 3-4 slider
-new 5-R slider
-heavy duty roll pins
-transmission is re-shimmed to Turbotrix Spec's
-new seals
Stage 1: $1400
Everything from our basic rebuild plus the following:
-new shift forks
-new 2nd gear
-new 3rd gear
-new 4th gear
-new 5th gear
-new bearings
Options:
Coating for gears and sliders : $250
Evo VIII 4th gear conversion: $225
Longer 1st gear: $320
Transfer case:
Stage 1: $2000
We take your transfer case, coat the ring and pinion, replace all seals, install a Quaife front diff, and upgrade the front cover bolts to 10mm.
Our transmissions and transfer cases have been tested, abused , and proven to hold 900+whp ever since our race car blasted into the 9's back in 2004. These transmission have been no-lift shifted at 10k+ RPM and have even held up to 10k rpm shifting with an ACT single disc clutch. Our transfercases have survived years of sixty foot abuse with the cars now pulling consistent mid to low 1.4's. If a fancy name re-assures you then you can call this trans the "Beansmacker " transmission. LOL, J/K We have had these transmissions and transfer cases in everything from a 350whp daily driver to a 9.1@159mph 1/4 mile monster.
Keith
Old Oct 19, 2007 | 08:34 AM
evolved83's Avatar
good to know i have another option, you guys are ultra close to me
Old Oct 19, 2007 | 09:52 AM
ExViTermini's Avatar
Mines gonna need a rebuild soon. Do the gears and forks usually take that much of a beating, or is that only for a really fubar'd unit?
The Beansmacker....LMAO.
Beansmacker lays the smackdown all over your Bushwacker, bietch!
Old Oct 21, 2007 | 09:07 AM
Matt2.8NJ's Avatar
What about the 6speed? Should we give up on life?
Old Oct 22, 2007 | 07:38 AM
I've done a few 6 speeds. They are just a lot more expensive. You have to order the entire 1-2 shaft. You can't buy and 1st or 2nd gear parts seperately. That shaft alone is around $1200.
Keith
Old Oct 23, 2007 | 08:17 AM
Soon2BEVO's Avatar
Yes
There is not getting around that weak 3rd and 4th gear. The cost of rebuliding them also like Keith said, is a lot. I think your best bet is to look for a used 5 speed or save up for a 5speed. If you are keeping your car for the long haul its a good idea! More peace of mind having that stronger 4th, and knowing it will be cheaper to build, worst case scenario.
However, if youre 6spd is in good shape, I bet you could sell it for more than buying a used 5 speed! Thats a thought too!
Old Oct 23, 2007 | 09:12 AM
rcheung's Avatar
Do you offer double fifth gear syncros?
Old Oct 23, 2007 | 08:53 PM
vwjeff's Avatar
try again there hero
Old Oct 23, 2007 | 09:21 PM
Duby's Avatar
What's the turn around time ?
Old Oct 24, 2007 | 07:43 AM
WOW!.....The "Beansmacker" name was a joke, and ExViTermini's comment was a joke too. Put down your Buschur pom-pom's for a minute. Have you ever shifted one of my transmissions? If you have nothing good to contribute then stay out of our thread.
Keith
Old Oct 24, 2007 | 07:47 AM
Anywhere from a few days to a week depending on parts availability and what stage trans your getting. I usually try to keep most of the stuff in stock.
Keith
Old Oct 24, 2007 | 07:48 AM
Its in the works.
Keith
Old Oct 24, 2007 | 03:40 PM
Evo4u2envY's Avatar
Obviously you've never shifted one of Keiths trannys, so till then quit your hating. The only thing you should be giving a thumb down to are the 2 letters in your name. V and W. Good day!
Old Oct 24, 2007 | 03:48 PM
I always think its a good idea to change the forks. As for the gears...it depends on how they look when its taken apart.
Keith
Old Oct 24, 2007 | 06:26 PM
Keith
Maybe we can identify that piece of metal on my drainplug, haha.
