TTP-Engineering excited about ZEITRONIX DashDAQ!
Old Apr 25, 2008 | 09:56 AM
TTP Engineering's Avatar
Zeitronix-DashDAQ
Full color, ODBII compatible Touch Screen Display for the Zt-2 Wideband AFR Meter
4" Touch-Screen offers 480x272 resolution using TFT LCD technology.
24-bit full color display with contrast ratio of 350:1
Dimensions are 4.6” x 2.75” x 1”, weight is only 0.5 lbs, (117mm x 70mm x 26mm, 273 grams)
Display AFR, RPM, EGT, Vacuum/Boost, TPS, and User Input from your Zt-2
Full ODBII support for display of parameters such as Mass Air Flow, Spark Advance, Coolant Temperature, and many more!
Data logging support onto removable MMC/SD memory -- no laptop or PDA required.
Auto Adjusting backlight, night mode, and low power standby.
Calculate Horsepower, Torque, and Performance, MPG and set configurable trip counters.
Simple and secure windshield-mounted display.
Optional GPS Navigation support with software developed by Drew Tech and Elektrobit.
Configurable Screens
Full color analog gauges!
Different 'skins' allow you to change the look and style of your display.
Many other page layouts and styles available.
Graph Zt-2 data points in real time: AFR, RPM, TPS, EGT, Vacuum-Boost, and User Input!
Mix and Match ODBII and Zt-2 data.
Data Logging:
Log Zt-2 and ODBII data on optional MMC/SD memory cards (up to 4GB in size).
Supports Full ODBII for 1996 and newer vehicles.
Logs the Zt-2 parameters from any vehicle.
Log and View up to 24 parameters at once!
Equipped with a special cable to log the Zt-2 data.
Log for hours
Zeitronix DashDAQ Packages:
Zt-2 + DashDAQ Bundle Complete Zeitronix Data logging System with DashDAQ™ display plus connector cable. The Display is preconfigured with Zeitronix driver and screens.
DashDAQ Display Add a DashDAQ™ to your Zt-2 system, includes DashDAQ™ and cable required to connect to the Zt-2. The Display is preconfigured with Zeitronix driver and screens.
Click HERE to ask questions or PLACE AN ORDER!
Old Apr 25, 2008 | 10:25 AM
Balrok's Avatar
We've been beta testing one of these for Dash and Zetronix for about 4 months now on a friends Lotus Elise, looks very promising! Bump for a good product combo!
Old Apr 25, 2008 | 10:58 AM
o-townFLA's Avatar
damn thats a nice lookin piece
Old Apr 28, 2008 | 01:10 PM
DrEvil's Avatar
nice unit but is it removable ?like when i shut down the beast and want to unplug the dashdaq to take inside my house like a head unit or do i have to complete unplug it from the ZT-2 to take out ?
Old Apr 28, 2008 | 09:51 PM
Zeitronix's Avatar
DashDAQ is easily removable, just unplug 2 connectors. One goes to the ODBII the second one to the Zt-2. You can mix and match ODBII and Zt-2 signals, record the data on the flash card, setup your favorite gauges, graphs etc.
Old Apr 28, 2008 | 10:18 PM
Sky Evo X's Avatar
Looks very sweet. You got a PM.
Old Apr 30, 2008 | 10:32 AM
ct9a_mr's Avatar
Looks great! Once I get a zt2 I will be looking at this.
Old Apr 30, 2008 | 10:37 AM
Evoryder's Avatar
nICE. So this obviously takes over the standard zt2 display.
Old Apr 30, 2008 | 11:42 AM
Ev0ikon's Avatar
Awww.. How purdy!
Please PM me with the price for the dislay. I already have the Zt2 and such...
Old Apr 30, 2008 | 11:46 AM
Nez136's Avatar
thats fricken sweet
Old May 1, 2008 | 10:16 AM
Ours should be here by tomorrow! Going on the X!
Old May 6, 2008 | 02:10 PM
Our DASHDAQ unit is in. Should be installing it over the next few days!
Old May 6, 2008 | 02:48 PM
Ph3n1x's Avatar
That bish looks hot.
Old May 8, 2008 | 07:25 AM
gkania's Avatar
Can it be used to read and clear codes too?
Old May 8, 2008 | 03:00 PM
Zeitronix's Avatar
Yes
