EvolutionM.net's ZEITRONIX Master Distributor!
Old Jun 21, 2008 | 12:17 PM
TTP Engineering's Avatar
TTP-Engineering would like to announce that we are the Master Distributor for Zeitronix products here on evolutionm.net.
As the innovator of a number of features the zeitronix is now capable of, we continue to work on the development team to help find new ways the system can benefit the end user.
Our trademarked meth injection safeguard system leaves much to be desired from every other wideband in the marketplace.
If anyone has any questions about the system, its features or components, options prior to purchasing, please feel free to contact us.
WE HAVE ALWAYS AND WILL CONTINUE TO SUPPORT ALL OF OUR ZEITRONIX CUSTOMERS WHO NEED INTELLECTUAL ADVICE IN APPLICATION AND USE OF THEIR UNIT.
FROM WIRING SCHEMATICS, TO PROPRIETARY WIRING APPLICATIONS WE HAVE DEVELOPED, WE ARE MORE THAN WILLING TO SUPPORT OUR CUSTOMERS WHO HAVE PURCHASED ZEITRONIX PRODUCTS THROUGH US.
QUESTIONS CAN BE DIRECTED TO (407) 475-0010 or EMAILED TO SALES @TTP-ENGINEERING.COM
Below are some example packages that are offered and are IN STOCK.
No dropshipping of products (fake inventory lists)
Package #ZR1R- Send us a PM!
Zeitronix ZT2 wideband PLUS ALL NEW ZR-1 GAUGE IN RED LED that displays AFR. Also for use with laptop for viewing, logging up to 9 hours of datalogging of RPM, TPS, AFR, Lambda, and Aux input 0-5v straight out of the box.
Includes the ZR-1 Gauge plus Zt-2 Wideband Air/Fuel Ratio Meter, Wideband Oxygen Sensor, Sensor Harness, Signal Harness, PC Serial Cable, Datalogging Software, Installation Instructions, 2 pin EGT connector to retrofit your EGT probe and ZR-1 Gauge with peak and hold feature. High contrast LEDs visible even in a direct sunlight. Made in the USA.
__________________________________________________ ___________
Package #ZR1B- Send us a PM!
Zeitronix ZT2 wideband PLUS ALL NEW ZR-1 GAUGE IN BLUE LED that displays AFR. Also for use with laptop for viewing, logging up to 9 hours of datalogging of RPM, TPS, AFR, Lambda, and Aux input 0-5v straight out of the box.
Package #ZR2BL- Send us a PM!
Zeitronix ZT2 wideband PLUS ALL NEW ZR-2 GAUGE IN BLUE LED Multi Gauge Combo which can display AFR, BOOST, EGT or LAMBDA and is switchable! Also for use with laptop for viewing, logging up to 9 hours of datalogging of RPM, TPS, AFR, Lambda, and Aux input 0-5v straight out of the box. Includes the ZR-2 Multi Gauge and Zt-2 Wideband Air/Fuel Ratio Meter, Wideband Oxygen Sensor, Sensor Harness, Signal Harness, PC Serial Cable, Datalogging Software, Installation Instructions, 2 pin EGT connector to retrofit your EGT probe and ZR-1 Gauge with peak and hold feature. High contrast LEDs visible even in a direct sunlight. Made in the USA.
Zeitronix ZT2 wideband only for use with laptop for viewing, logging up to 9 hours of datalogging of RPM, TPS, AFR, Lambda, and Aux input 0-5v straight out of the box.
Includes the Zt-2 Wideband Air/Fuel Ratio Meter, Wideband Oxygen Sensor, Sensor Harness, Signal Harness, Datalogging Software, Installation Instructions and 2 pin EGT connector to retrofit your EGT probe.
Zeitronix ZT2 wideband PLUS BLACK ANODIZED LCD SCREEN that displays, TPS, BOOST, AFR, Aux 0-5v input. Also for use with laptop for viewing, logging up to 9 hours of datalogging of RPM, TPS, AFR, Lambda, and Aux input 0-5v straight out of the box.
Zeitronix ZT2 wideband PLUS BLACK ANODIZED LCD SCREEN that displays, TPS, BOOST, AFR, Aux 0-5v input. ALSO INCLUDES 3.5BAR (35.5psi) medical grade precision MAP sensor for boost logging! Also for use with laptop for viewing, logging up to 9 hours of datalogging of BOOST, RPM, TPS, AFR, Lambda, and Aux input 0-5v straight out of the box.
Zeitronix ZT2 wideband PLUS BLACK ANODIZED LCD SCREEN that displays, TPS, BOOST, AFR, Aux 0-5v input. ALSO INCLUDES 3.5BAR (35.5psi) medical grade precision MAP sensor for boost logging. Also includes low mass, high response K thermocouple EGT sensor for lightning quick EGT logging and viewing on the LCD display. Also for use with laptop for viewing, logging up to 9 hours of datalogging of BOOST, EGT, RPM, TPS, AFR, Lambda, and Aux input 0-5v straight out of the box.
Zeitronix ZT2 wideband PLUS BLACK ANODIZED LCD SCREEN that displays, TPS, BOOST, AFR, Aux 0-5v input. ALSO INCLUDES 3.5BAR (35.5psi) medical grade precision MAP sensor for boost logging. Also includes low mass, high response K thermocouple EGT sensor for lightning quick EGT logging and viewing on the LCD display. Also includes ZAVT- Zeitronix AUDIO-VISUAL alarm and safeguard trigger. FULLY PROGRAMMABLE warning LED and alarm that you can bas on simple EGT, AFR, BOOST, TPS, RPM and/or COMPLEX warning such as (IF AFR> 12.00 AND BOOST >22PSI AND TPS> 75%, THEN TRIGGER WARNING). This feature works especially well with TTP-Engineering's meth injection systems to insure a trouble free tune. Also for use with laptop for viewing, logging up to 9 hours of datalogging of BOOST, EGT, RPM, TPS, AFR, Lambda, and Aux input 0-5v straight out of the box.
[/B]
Old Jun 27, 2008 | 10:42 PM
Yes we stock the DASHDAQ touchscreen display with optional GPS also!
Old Jul 3, 2008 | 01:51 PM
KidEvo's Avatar
bump
Old Aug 4, 2008 | 12:51 PM
KidEvo's Avatar
Restock has arrived. PM TTP for details!
Old Aug 6, 2008 | 02:45 PM
[/B]
PM us what package you are interested in!
Old Aug 6, 2008 | 04:00 PM
compscibOi's Avatar
I got an email from Zeitronix today:
from Marc Berretta <marc@zeitronix.com>
reply-to sales@zeitronix.com
date Wed, Aug 6, 2008 at 6:00 PM
subject Zeitronix Order - Thank you
mailed-by yourhostingaccount.com
Thank you for your recent order. We enjoy it here when people buy T-shirts, this usually means a very happy customer. The reason I am writing you is because we are setting up a customer quotes page and gallery. If you have any pictures you would like to submit with yourself, your vehicle, or Zeitronix display we would greatly appreciate it. We could also use some quotes about quality, ease of use, software, comparisons, or just general overall impressions on the product if you would like to make some. We will also include your name, city, and state if you like. Please send any pictures or quotes to sales@zeitronix.com.
Thanks again,
Best regards,
Marc Berretta
www.zeitronix.com
(310) 833 - 3450 [M-F 10am - 4pm Pacific Time]
marc@zeitronix.com
Zeitronix - YOUR ULTIMATE TUNING PARTNER
I gave him my thread - what a cool company.
Old Aug 20, 2008 | 07:21 AM
Congrats on making the cut for customer cars on their site!
Thanks again,
Best regards,
Marc Berretta
www.zeitronix.com
marc@zeitronix.com
Old Sep 11, 2008 | 09:17 AM
KidEvo's Avatar
Several units in stock and ready for shipping!
Old Sep 24, 2008 | 02:19 PM
Veronica@TTP's Avatar
Just re-stocked, great items ready for shipping!
Old Sep 27, 2008 | 10:38 AM
evo8426's Avatar
shipped to 28174?
Old Sep 28, 2008 | 03:33 PM
Gordian79's Avatar
Zeitronix-DashDAQ Series-II with zt-2 shipped to 10460?
Old Oct 1, 2008 | 09:19 AM
New shipment has arrived, PM's will be returned asap!
Old Dec 10, 2008 | 08:28 AM
Expect all new ZEITRONIX product debuts to hit the shelves of TTP-Engineering first!
Old Dec 16, 2008 | 12:13 PM
Call to order your Zeitronix products today!
Old Dec 23, 2008 | 10:00 AM
lots in stock ready to ship!
