-   Vendor Announcements (https://www.evolutionm.net/forums/vendor-announcements-235/)
-   -   EvolutionM.net's ZEITRONIX Master Distributor! (https://www.evolutionm.net/forums/vendor-announcements/352910-evolutionm-nets-zeitronix-master-distributor.html)
TTP Engineering Jun 21, 2008 12:17 PM
TTP-Engineering would like to announce that we are the Master Distributor for Zeitronix products here on evolutionm.net.
As the innovator of a number of features the zeitronix is now capable of, we continue to work on the development team to help find new ways the system can benefit the end user.
Our trademarked meth injection safeguard system leaves much to be desired from every other wideband in the marketplace.
If anyone has any questions about the system, its features or components, options prior to purchasing, please feel free to contact us.
WE HAVE ALWAYS AND WILL CONTINUE TO SUPPORT ALL OF OUR ZEITRONIX CUSTOMERS WHO NEED INTELLECTUAL ADVICE IN APPLICATION AND USE OF THEIR UNIT.
FROM WIRING SCHEMATICS, TO PROPRIETARY WIRING APPLICATIONS WE HAVE DEVELOPED, WE ARE MORE THAN WILLING TO SUPPORT OUR CUSTOMERS WHO HAVE PURCHASED ZEITRONIX PRODUCTS THROUGH US.
QUESTIONS CAN BE DIRECTED TO (407) 475-0010 or EMAILED TO SALES @TTP-ENGINEERING.COM
Below are some example packages that are offered and are IN STOCK.
No dropshipping of products (fake inventory lists)
http://ttp-engineering.com/catalog/i...2kit400RED.jpg
Package #ZR1R- Send us a PM!
Zeitronix ZT2 wideband PLUS ALL NEW ZR-1 GAUGE IN RED LED that displays AFR. Also for use with laptop for viewing, logging up to 9 hours of datalogging of RPM, TPS, AFR, Lambda, and Aux input 0-5v straight out of the box.
Includes the ZR-1 Gauge plus Zt-2 Wideband Air/Fuel Ratio Meter, Wideband Oxygen Sensor, Sensor Harness, Signal Harness, PC Serial Cable, Datalogging Software, Installation Instructions, 2 pin EGT connector to retrofit your EGT probe and ZR-1 Gauge with peak and hold feature. High contrast LEDs visible even in a direct sunlight. Made in the USA.
__________________________________________________ ___________
http://ttp-engineering.com/catalog/images/Zt2kit400.jpg
Package #ZR1B- Send us a PM!
Zeitronix ZT2 wideband PLUS ALL NEW ZR-1 GAUGE IN BLUE LED that displays AFR. Also for use with laptop for viewing, logging up to 9 hours of datalogging of RPM, TPS, AFR, Lambda, and Aux input 0-5v straight out of the box.
http://ttp-engineering.com/catalog/images/ZR2gauge.jpg
http://zeitronix.com/order/Zt2kit150.jpg
Package #ZR2BL- Send us a PM!
Zeitronix ZT2 wideband PLUS ALL NEW ZR-2 GAUGE IN BLUE LED Multi Gauge Combo which can display AFR, BOOST, EGT or LAMBDA and is switchable! Also for use with laptop for viewing, logging up to 9 hours of datalogging of RPM, TPS, AFR, Lambda, and Aux input 0-5v straight out of the box. Includes the ZR-2 Multi Gauge and Zt-2 Wideband Air/Fuel Ratio Meter, Wideband Oxygen Sensor, Sensor Harness, Signal Harness, PC Serial Cable, Datalogging Software, Installation Instructions, 2 pin EGT connector to retrofit your EGT probe and ZR-1 Gauge with peak and hold feature. High contrast LEDs visible even in a direct sunlight. Made in the USA.
Zeitronix ZT2 wideband only for use with laptop for viewing, logging up to 9 hours of datalogging of RPM, TPS, AFR, Lambda, and Aux input 0-5v straight out of the box.
Includes the Zt-2 Wideband Air/Fuel Ratio Meter, Wideband Oxygen Sensor, Sensor Harness, Signal Harness, Datalogging Software, Installation Instructions and 2 pin EGT connector to retrofit your EGT probe.
http://zeitronix.com/order/LCDdisplay_small_black.jpg
Zeitronix ZT2 wideband PLUS BLACK ANODIZED LCD SCREEN that displays, TPS, BOOST, AFR, Aux 0-5v input. Also for use with laptop for viewing, logging up to 9 hours of datalogging of RPM, TPS, AFR, Lambda, and Aux input 0-5v straight out of the box.
http://zeitronix.com/order/MAP-120.jpg
Zeitronix ZT2 wideband PLUS BLACK ANODIZED LCD SCREEN that displays, TPS, BOOST, AFR, Aux 0-5v input. ALSO INCLUDES 3.5BAR (35.5psi) medical grade precision MAP sensor for boost logging! Also for use with laptop for viewing, logging up to 9 hours of datalogging of BOOST, RPM, TPS, AFR, Lambda, and Aux input 0-5v straight out of the box.
http://zeitronix.com/order/EGT130.jpg
Zeitronix ZT2 wideband PLUS BLACK ANODIZED LCD SCREEN that displays, TPS, BOOST, AFR, Aux 0-5v input. ALSO INCLUDES 3.5BAR (35.5psi) medical grade precision MAP sensor for boost logging. Also includes low mass, high response K thermocouple EGT sensor for lightning quick EGT logging and viewing on the LCD display. Also for use with laptop for viewing, logging up to 9 hours of datalogging of BOOST, EGT, RPM, TPS, AFR, Lambda, and Aux input 0-5v straight out of the box.
http://ttp-engineering.com/catalog/images/ZAVT120.jpg
Zeitronix ZT2 wideband PLUS BLACK ANODIZED LCD SCREEN that displays, TPS, BOOST, AFR, Aux 0-5v input. ALSO INCLUDES 3.5BAR (35.5psi) medical grade precision MAP sensor for boost logging. Also includes low mass, high response K thermocouple EGT sensor for lightning quick EGT logging and viewing on the LCD display. Also includes ZAVT- Zeitronix AUDIO-VISUAL alarm and safeguard trigger. FULLY PROGRAMMABLE warning LED and alarm that you can bas on simple EGT, AFR, BOOST, TPS, RPM and/or COMPLEX warning such as (IF AFR> 12.00 AND BOOST >22PSI AND TPS> 75%, THEN TRIGGER WARNING). This feature works especially well with TTP-Engineering's meth injection systems to insure a trouble free tune. Also for use with laptop for viewing, logging up to 9 hours of datalogging of BOOST, EGT, RPM, TPS, AFR, Lambda, and Aux input 0-5v straight out of the box.
http://www.ttp-engineering.com/ZT2za...ARD%20copy.jpg[/B]
TTP Engineering Jun 27, 2008 10:42 PM
Yes we stock the DASHDAQ touchscreen display with optional GPS also!
KidEvo Jul 3, 2008 01:51 PM
bump
KidEvo Aug 4, 2008 12:51 PM
Restock has arrived. PM TTP for details! :beer:
TTP Engineering Aug 6, 2008 02:45 PM
PM us what package you are interested in!
compscibOi Aug 6, 2008 04:00 PM
I got an email from Zeitronix today:
from Marc Berretta <marc@zeitronix.com>
reply-to sales@zeitronix.com
date Wed, Aug 6, 2008 at 6:00 PM
subject Zeitronix Order - Thank you
mailed-by yourhostingaccount.com
Thank you for your recent order. We enjoy it here when people buy T-shirts, this usually means a very happy customer. The reason I am writing you is because we are setting up a customer quotes page and gallery. If you have any pictures you would like to submit with yourself, your vehicle, or Zeitronix display we would greatly appreciate it. We could also use some quotes about quality, ease of use, software, comparisons, or just general overall impressions on the product if you would like to make some. We will also include your name, city, and state if you like. Please send any pictures or quotes to sales@zeitronix.com.
Thanks again,
Best regards,
Marc Berretta
www.zeitronix.com
(310) 833 - 3450 [M-F 10am - 4pm Pacific Time]
marc@zeitronix.com
Zeitronix - YOUR ULTIMATE TUNING PARTNER
I gave him my thread - what a cool company.
TTP Engineering Aug 20, 2008 07:21 AM
Congrats on making the cut for customer cars on their site! {thumbup}
Thanks again,
Best regards,
Marc Berretta
www.zeitronix.com
marc@zeitronix.com
KidEvo Sep 11, 2008 09:17 AM
Several units in stock and ready for shipping!
Veronica@TTP Sep 24, 2008 02:19 PM
Just re-stocked, great items ready for shipping!
evo8426 Sep 27, 2008 10:38 AM
shipped to 28174?
Gordian79 Sep 28, 2008 03:33 PM
Zeitronix-DashDAQ Series-II with zt-2 shipped to 10460?
Veronica@TTP Oct 1, 2008 09:19 AM
New shipment has arrived, PM's will be returned asap!
TTP Engineering Dec 10, 2008 08:28 AM
Expect all new ZEITRONIX product debuts to hit the shelves of TTP-Engineering first!
http://ttp-engineering.com/catalog/i...75_siteart.jpg
Veronica@TTP Dec 16, 2008 12:13 PM
Call to order your Zeitronix products today!
Veronica@TTP Dec 23, 2008 10:00 AM
lots in stock ready to ship!
