*ams Product Release* Evo Cnc Cylinder Heads!!!
Old Aug 20, 2008 | 07:30 PM
1d10t's Avatar
I used to run a flow bench for DPRracing, and I gotta tell you. Theyre good numbers. That flows almost like a Honda head. The cool thing about CnC is each port is identical. Nice work guys
Old Aug 25, 2008 | 02:24 PM
Aby@MIL.SPEC's Avatar
any idea how a unported head would stack up in the dyno chart?
Old Aug 28, 2008 | 10:28 AM
MR Turco's Avatar
Will you have options for different valves? Would 1mm over stock be too big for a stock turbo - what are the advantages/disadvantages? Will you offer just the CNC bare head without the valves and springs?
Old Aug 28, 2008 | 06:49 PM
ecuflasher's Avatar
Have you released the pricing?
Old Aug 29, 2008 | 05:26 AM
MR Turco's Avatar
They didnt in this thread but they did in their vendor section:
Pricing:
AMS CNC EVO 8 Head - New head, no core needed - $3995.00
AMS CNC EVO 9 Head - New head, no core needed - $4095.00
AMS CNC EVO 8 Head - With Core - $2595
AMS CNC EVO 9 Head - With Core - $2695
Core heads are stripped, cleaned, new guides, seals, ect.
Old Sep 29, 2008 | 02:54 PM
AutoMotoSports's Avatar
These are now available for purchase on our site
http://www.amsperformance.com/store/...Path=22_44_298
Old Oct 2, 2008 | 08:51 AM
Chris@AMS's Avatar
Excellent Results From The New AMS CNC Head!!
Jared brought his car back to us solely for the addition of the new AMS CNC head and a re-tune on 93oct pump gas. Ivan strapped the head on the car and I had an opportunity to get it on the dyno last night. The results are very impressive to say the least. The only thing changed on the car was the head. Everything else was left exactly the same.
A few details:
AMS 850R kit
AMS Standard FMIC!!
AMS Intake Manifold
No other changes made at all
93oct pump gas
23.5 PSI
For those of you that like chewing on hard data, Here is the difference in Fueling at 23 psi.
Old Oct 2, 2008 | 08:52 AM
Billy@EnglishRacing's Avatar
looks great
Old Oct 2, 2008 | 03:16 PM
thank you. we can't wait to see the gains in going from a Cosworth head to an AMS head on our drag car. The Flow test numbers were pretty substantial.
Eric
Old Oct 2, 2008 | 04:52 PM
Batmann!'s Avatar
A few details:
AMS 850R kit
AMS Standard FMIC!!
AMS Intake Manifold
93oct pump gas
23.5 PSI
What is the size of the injectors that he is using?
Old Oct 2, 2008 | 04:55 PM
He is on 1000CC injectors right now.
Eric
Old Oct 2, 2008 | 05:47 PM
Batmann!'s Avatar
Eric
Shouldn't he be on at least 1200cc with that setup? What happens if he uses C16 and cranks up the boost?
Old Oct 2, 2008 | 08:57 PM
thatsMR2u's Avatar
nice dyno # compare- but the better the flow- the lower the detonation the more timing you can add- so definatly more power can be made with tuning!
Old Oct 3, 2008 | 07:11 AM
Chris@AMS's Avatar
That is what is being shown.
What is your point exactly?
Old Oct 3, 2008 | 07:19 PM
thatsMR2u's Avatar
so you added changed the tune with each port job?
