*AMS PRODUCT RELEASE* EVO X Fuel Rail
Old Oct 2, 2008 | 04:47 PM
AutoMotoSports's Avatar
The AMS EVO X Fuel Rail provides increased fuel flow which is necessary at higher boost levels. This CNC’d aluminum rail comes anodized in Red or Black and includes our signature AMS logo. With a -6AN (7.5 mm) diameter inlet and outlet it dwarfs the stock rail by over 25% in flow area. This is true bolt on part that will install with your factory fuel lines, fuel pressure regulator and will work with all factory style fuel injectors. In addition it comes with a 1/8” NPT port where you can mount a fuel pressure gauge or use it for an auxiliary fuel port.
Included in our kit is a -6AN braided fuel feed line that increases fuel flow by 25%. Our line also makes your car safer by eliminating the hard factory fuel feed line that can crack over time from engine vibration.
Features
  • Precision CNC machined from 6061 billet aluminum
  • -6AN (7.5mm) fuel inlet increases fuel flow by 25%
  • Thick flanges and stantions for durability and reliability
  • Direct bolt-on, no modifications needed
  • AMS Logo CNC’d into the face of the rail
  • Retains factory fuel pressure regulator
  • Works with all factory style fuel injectors
  • Available in anodized Red or Black
Specifications
  • CNC machined 6061 billet aluminum
  • 7.5mm inlet and 11mm return port
  • .25 inch thick flanges
  • 1/8” NPT port with removable stainless steel plug
  • -6AN black braided fuel feed line with black anodized fitting
Options
  • Red or Black anodized
Applications
  • Mitsubishi Evolution X GSR & MR
  • Fits all USDM, JDM and European Models
Retail: 239.95
Click HERE to Order!
