Labonte - New Digital Demand Pump, Raises the Bar
For years almost everyone has been using the same old 150psi pump for meth-injection. Not any more. The new DDP-5800 from LMS reaches new performance levels for methanol-injection.
Higher pressure leads to better atomization and faster intake charge cooling, and this pump delivers. Capable of making up to 250psi, fluid particles can be atomized down to 15-25 microns.
Unlike existing pumps with a pressure cut out switch, the DDP-5800 has an internal bypass which re-circulates fluid. This allows for more consistent pressure without pump cycling. The pump pressure is also user adjustable from 150 – 250psi (Factory preset at 200psi). The DDP-5800 is self priming and compatible with methanol or ethanol.
Another design improvement is the built in ¼” hose connection fittings. This simplifies install and reduces the number of system leak points for increased reliability. Pump length and mounting base are the same as older 150 pumps allowing for simple upgrade.
The DDP-5800 is now the standard injection pump included with all Labonte MotorSports meth-injection systems. MSRP $129.00
Will this pump support 5 injectors "4 of them M5" and 1 of them a M7 or would i be better off going with two pumps to support it? Also since i run stainless line is there any way to get fittings for the pump to support a -4 line?
Thanks
Chris
Thanks
Chris
FS[SouthEast]: Snow performance Water/Meth Injection Kit
Kustom09art
Southeast Region
Oct 30, 2015 04:28 PM
Anarchy99
13
Jan 20, 2012 12:52 PM
maperformance
Sep 7, 2010 01:39 PM
Labonte MotorSports
57
Jul 15, 2009 09:07 PM
4WS Tuning
29
Jul 16, 2008 10:34 PM
