Cobb Tuning Evo X Hard Pipe Kit Now Available!
Old Oct 21, 2008 | 09:23 PM
maperformance's Avatar
Uncompromising quality and features put COBB hard-pipe kit at the top.
COBB Tuning unveils its latest performance piece for the EVO X, the COBB Intercooler Hard-Pipe Kit, and it does not fail to
impress. It is currently the only kit that replaces ALL intercooler pipes (including the BPV) with weld-free single-pipe aluminum
tubing. This uncompromising kit has the most comprehensive list of performance enhancing features available. Add the
precision fit and one-of-a-kind appearance and it is clear that the COBB Intercooler Hard-Pipe kit for the EVO X is unequaled.
As with all intercooler hard-pipe kits, the stock rubber hoses to the intercooler are replaced with solid pipes to eliminate
distortion under boost. But the devil is in the details, and that is where similarities end. The COBB EVO X Hard-Pipe Kit
consists of single piece pipes made from mandrel bent aluminum tubing on both the cold side and hot side of the
intercooler. The results are weld-free pipes from the turbo outlet to intercooler inlet and from the intercooler outlet to
the throttle body, without unsightly mid-pipe silicone hose couplings that can disrupt flow or potentially blow off under
boost. The hot and cold pipe diameters are increased from the stock 2.375” to 2.5”, enhancing flow even further.
The By-Pass-Valve (BPV) gets its own hard-pipe from the cold side of the intercooler, maintaining the factory location and
orientation. Maintaining this connection from the cold side ensures that cool air is fed back to the intake system when the
valve is in bypass mode, preventing overheating of the air charge post turbo. The BPV is located using a visually stunning
COBB logo bridge that connects the BPV hard-pipe to the hot side hard-pipe.
The COBB EVO X Hard-Pipe kit is one of the very few that will fit with the factory air box in place (or the optional COBB SF
Intake) as well as the stock front engine cover. The kit is completed with high quality COBB silicone hose couplings and
heavy duty T-Bolt hose clamps to eliminate those embarrassing hose blow-offs than can occur when demanding the most from your EVO X.
The kit is available in Gunmetal powder coat or can be special ordered in high polished aluminum finish. Painstaking effort goes
in to the fabrication, handling and packaging of our high polish kit, ensuring the parts arrive with a beautiful unblemished finish.
EVO X Intercooler Hard-Pipe Features:
• Hot side pipe is single piece, weld-free
mandrel bent aluminum tubing increased to 2.5”
• Cold side pipe is single piece, weld-free mandrel
• Minimal hose couplings for clean appearance
and reduced blow-off potential
• OEM BPV location and orientation
maintained with BPV hard-pipe
• Eye-catching COBB logo hard-pipe bridge
• Fits with OEM airbox or optional COBB SF Intake
• Fits with OEM engine cover
• COBB silicone hose couplings
• Heavy duty T-Bolt hose clamps
• Gunmetal powder coat or high polish aluminum
Pricing is just $595 for Gunmetal and $695 for Polished and as always shipping is FREE with MAPerformance!
Old Oct 22, 2008 | 08:18 AM
Bump!
Old Oct 22, 2008 | 02:35 PM
Bump!
Old Oct 22, 2008 | 02:36 PM
btownsoccer22's Avatar
DANG if i had an X this is what i would get
Old Oct 22, 2008 | 04:25 PM
Yeah this seems to be a very well made piece!
Old Oct 23, 2008 | 08:01 AM
Bump.
Old Oct 23, 2008 | 04:03 PM
Bump to the top.
Old Oct 24, 2008 | 07:59 AM
Bump.
Old Oct 24, 2008 | 04:16 PM
Bumpin.
Old Oct 27, 2008 | 07:47 AM
Bump.
Old Oct 27, 2008 | 04:47 PM
Bump.
Old Oct 28, 2008 | 09:17 AM
Bump.
Old Oct 28, 2008 | 04:39 PM
Bumpin.
Old Oct 29, 2008 | 07:50 AM
Bump.
Old Oct 29, 2008 | 02:48 PM
Bump.
