The new and affordable high performacne metering gauges are here!!!
BLOX Racing 52mm Boost Gauge
Reads Boost and vacuum pressure up to 30psi!
The BLOX Racing series of 52mm gauges feature a classic look with a white background and green backlight. Each gauge is clearly marked and highly visible and comes with all the necessary mounting hardware and hose connections.
Part #: BXGA-00000
MSRP: $63.90 each
Speed Element Introductory Offer: $57 Free Shipping!
BLOX Racing 52mm EGT Gauge
Measures E.G.T in F-Degrees, Range: 6x22 x100 F-Degrees
Part #:BXGA-00004
MSRP: $202 each
Speed Element Introductory Offer: $170 Free Shipping!
BLOX Racing 52mm Liquid-Filled Fuel Pressure Gauge Kit
Measures Fuel Pressure in PSI. Range: 0-100 PSI.
Part #: BXGA-00111
MSRP: $50
Speed Element Introductory Offer: $45 Free Shipping!
BLOX Racing 52mm Oil Pressure Gauge
Measures Oil Pressure in PSI. Range: 0-100psi.
Part #: BXGA-00005
MSRP: $69.99
Speed Element Introductory Offer: $60 Free Shipping!
BLOX Racing 52mm Oil Temp Gauge
Measures Oil Temperature in F-Degrees. Range: 120-300 F-Degrees.
Part #: BXGA-00007
MSRP: $69.99
To Order, Please give us a call 510-353-1021
Web Order, please click here:
http://www.speedelement.com/index.ph...mart&Itemid=38
For BLOX Racing Performance Gauge Combos, Please feel free to send us a PM Inquiry!!
Part #: BXGA-00000
MSRP: $63.90 each
Part #:BXGA-00004
MSRP: $202 each
Part #: BXGA-00111
MSRP: $50
Part #: BXGA-00005
MSRP: $69.99
Part #: BXGA-00007
MSRP: $69.99
Quote:
oil temp gauge sensor is included in the kit. Originally Posted by kanyonkid
does oil temp come with the sensor? like the drainplug sensor on the MR's??
Quote:
I believe the factory Mitsubishi gauges are smaller.Originally Posted by Bizo2
can i replace my MR gauges with these blox gauges
You can try to fit these gauges but we can't guarantee anything tho..
Quote:
I think you should be able to.Originally Posted by Bizo2
sorry, i was talking about the wiring. can i just swap the MRs one with these
you should always use the wiring and sensors provided by the maker of the gauges. Otherwise the warranty will be voided.
yeah, I hear you on wiring part. It is real PITA.
But Pnutbutterwolf is right.. you should always use the wiring harness and sensors to get covered by the manufacturers warranty.
Thanks
Thanks
Quote:
my cousin has these gauges and I think for the price, they are really good quality gauges. Originally Posted by red evo8
"necessary mounting hardware" like a gauge cup that bolts to the steering column?
From what I observed, each Blox Racing gauge does not come w/ a gauge cup like the Defi's. But it does come with mounting bracket to allow users to mount on the dash, or steering column.
I am considering these as soon as I get some $ ready..
Quote:
BLOX Racing meters do not come w/ gauge cup, but the mounting hardware that came w/ the package will allow you to. Originally Posted by red evo8
Everything is in stock for immediate delivery!
For more questions or info, please give us a call or email!
510-353-1021
Thank you!
