WORKS Ohilns Stage 1 Suspension
Old Apr 7, 2009 | 07:21 PM
troy@WORKS's Avatar
WORKS offers a variety of different suspension kits for the EVO 8 and 9. The WORKS Stage 1 suspension kit is for the street and the track. The kit comes with Ohlins Fixed Perch 25-level rebound adjustable struts and shocks with WORKS Ride springs which can be pre-assembled with OEM hardware to make them a direct bolt in.
Old Apr 7, 2009 | 09:48 PM
hokiruu's Avatar
I have been curious and maybe even very interested in this suspension for a long time, and always come back to the big question:
How much negative front camber can be achieved with this suspension, with or without camber plates, and with how big of wheels and tires?
Can you please list the spring rates?
Old Apr 8, 2009 | 12:52 PM
troy@WORKS's Avatar
Just as with the stock suspension using the bolts you should be able to get 2 degrees of negative camber and with the WORKS front camber plates you should be able to get 3 degrees of negative camber.
Tires would be contingent on the offset of the wheels and how much negative camber you are planning on the car having.
The front springs are about 235lbs/in. and the rears are about 300lbs/in.
