ROAD/RACE-Timing Control Box Ready
Old Apr 27, 2009 | 10:23 PM
  #76
ROCK's Avatar
Originally Posted by Realistic
Rock, I was planning on using a standalone, will the standalone affect the timing control box? let me know what you think. I'm on the brink of order this mod, but I want to make sure its compatible when I go turbo. Also, did you send out my packages?
thanks,
Mike.
THis is not for turbo or for a standalone. THis is an N/A plug and play way to get 10 h.p. and a lot more punch!
ROAD/RACE
Old Apr 28, 2009 | 01:27 PM
  #77
rory_j13's Avatar
Ok so quick question... when it arrives and i install 1. should i reset the ecu and 2. when i do should i give it the usual 15 minutes to idle... basically when can i go wot cuz im so excited to get it that its hard for me to wait the 4 more business days to arrive
Old Apr 28, 2009 | 06:40 PM
  #78
ROCK's Avatar
Connect it with the battery disconected. That basically resets all. LEt the car idle for 10 minutes and then go. That should yield the best result.
ROAD/RACE
Old Apr 28, 2009 | 09:14 PM
  #79
Realistic's Avatar
so its a N/A mod?
damn.
Old Apr 29, 2009 | 04:08 AM
  #80
Thomar's Avatar
Since this changes the timing, I have a question:
Has this gadget been tested to see what happens to the engine if it malfunctions?
Any adverse affects?
Old Apr 29, 2009 | 09:44 PM
  #81
hackish's Avatar
Some check engine conditions force the ECU to use an alternate timing map. Since this is more conservative it is unlikely that the timing box will cause trouble with that. You will have to continuously monitor the ECU's idea of fuel octane and use the timing control box to only advance timing in the regions if an only if it detects your fuel as the max possible octane.
Basically, there are 2 timing and 2 fuel maps in the ECU. If it detects some knock then it assumes you're running bad fuel and pulls timing on pretty much all of the map by interpolating between the 2 maps. It also adds extra fuel.
From what I've decoded so far the ECU does not distinguish between knocking at 4000 RPM or 6000 RPM. So if you use a timing box to advance the timing too much in one area then you'll lose power all over the range. It will also add extra fuel that further reduces your power output. UGH times 2! Just make sure you don't run a lot of extra timing. I should have some dyno graphs shortly that show the effect of adding timing on various parts of the map.
I wasn't kidding when I said the ECU is really tricky!
Old Apr 30, 2009 | 04:37 PM
  #82
ROCK's Avatar
Yes. This is why it took so long to release. We check it on 4 cars and over a 1000 miles for sure. It is all good.
ROAD/RACE
Old May 4, 2009 | 01:58 PM
  #83
ROCK's Avatar
Who has one so far?
ROAD/RACE
Old May 4, 2009 | 07:49 PM
  #84
planetchaos's Avatar
Is it possible for someone to post a higher res picture of where the timing control box is plugged in. Also I can't wait for more reviews to come in. I'm Canadian and it's great to here that there wasn't any problems with customs.
Old May 5, 2009 | 02:19 PM
  #85
rory_j13's Avatar
ok just hooked it up...i'll do my best to get a better photo...it took me a half an hour including idle time...i really didnt want to break the plug..its tricky but you'll see. BTW its amazing and i only have that and injen cai installed... Still have to install my udp, lower tie bar and ss clutchline. Just need some spare time.
Old May 5, 2009 | 09:33 PM
  #86
ROCK's Avatar
You had me at amazing!!!!!! Tak like that and I will raise the price! JK
Glad you love it. IT is off the chain though! Hard work paid off.
ROAD/RACE
Old May 5, 2009 | 09:44 PM
  #87
Raikiri's Avatar
I was wondering where this thread went! I was searching through the RA forums for this.... anyway yes I'm looking for a better quality picture of it as well.. should be getting mine this friday so cant wait to put it on
does anyone have any tips to get the sensor off without damaging it? I took a look at it and at first glance it didnt look like the clip like the MAF sensor and seems a little more complicated... but I could've been seeing things
Old May 5, 2009 | 10:59 PM
  #88
vboy425's Avatar
bump for good people
Old May 6, 2009 | 06:15 AM
  #89
This is just an observation but it seems like the RA guys are more satisfied with the timing box than the 2008+ normal lancers. Or maybe they are just more accepting and are tying the thing before bashing on it.... Like I said it's just an observation.
Old May 6, 2009 | 01:30 PM
  #90
rory_j13's Avatar
yes actually take a phillips screw driver up the side of the metal clip. Start at the beginning of the metal and pull up. It comes off real easy then.
Like i said took me a while but doing it again 5 minutes.
As far as the comment about being excited and more satisfied.....Simple pleasures
