**Product Release**AMS Evolution X Brake Cooling Kit
The AMS EVO X Brake Cooling Kit was designed for heavy braking situations like those experienced during road race and autocross. In factory form, the brakes on the EVO provide great stopping power but after sustained heavy braking they can begin to fade. By forcing airflow directly through the rotor vents this kit drastically reduces the temperature of the rotors, brake pads and calipers. Reducing the temperature of your brakes defends against brake fade and provides longer pad life. By installing the AMS Brake Cooling Kit you will have consistent stopping power throughout your whole session. This kit replaces the factory dust shields with tighter fitting stainless steel shields and caliper ducts which forces more air to exit through the rotor vents. Very tight tolerances with the caliper ensure that all incoming air must pass through the rotor veins to cool the caliper. High temperature flexible silicon tubing is provided instead of cheap and weak dryer vent hosing that will deteriorate quickly. The aluminum air scoops provided are designed to be universal and fit in just about any opening in the bumper cover, even aftermarket body-kits.
Features
• Stainless steel construction for long life and good looks
• Tight tolerances ensure maximum cooling of your brakes
• High quality silicone tubing for long life
• Works with stock Brembo calipers, factory rotors, and upgraded factory replacement rotors
• Works with all factory and aftermarket front bumpers
Kit Includes
• Replacement dust shields
• Flexible silicone tubing
• Caliper ducts
• Air scoops
• All necessary hardware
Specifications
• 2.5” inch silicone tubing
• 304 stainless steel caliper duct and dust shields
• Aluminum air inlet
• custom tig welded tubing to get through the tight areas
• High Flow Naca Ducts for optimal airflow from the front bumper
Applications
• Mitsubishi Evolutions X with stock Brembo brakes
• Fits all USDM, JDM and European Models
INSTALLATION INSTRUCTIONS
Click Here
Click Here To Order
