Slowboy Racing will not be undersold!
It has been a very trying couple of weeks here at SBR. The move was harder than anyone expected it to be, but it's over. The sales guys are settling into their groove, the new shipping department looks great and has been shipping products out like crazy, and FINALLY the machine shop is fully powered up and cranking blocks and heads out again!
Now I'm not trying to fool anyone, look at my SN, I'm the admin here on this forum and I work for SBR. But this machine shop is a MUST see! If you are a car guy/girl, and you have to be if you're on this site, stop by and check out the machine shop and install area. Don't live in FL? Well the shop is only about 30 minutes from Disney so when you're here with the family, come on up!
When you do come up, make sure you meet Tim. Tim is in charge of our machine shop and he will give you the confidence that any machine work you need done will be the best quality you can get. He's also a slave driver (don't tell him that) so there is a really quick turnaround time.
We work very close with our friends at BC and we can offer you great pricing on their excellent line of products!
Cams
Valve Spring and Retainer Kits
Valves
Stroker Kits
Let us know what kind of engine we can help you build and we will work to help you reach your goals!!!!!
Slowboy Racing, Inc.
Slowboy Racing Inc. - The performance experts for factory turbocharged vehicles. - Homepage
Cams
Valves
Stroker Kits
Timing and rebuild kits!!!
EVO VIII Rebuild Kit!
With all of these motors being built, we get asked all the time for lists of what parts are needed, what we recommend and stuff as well. I went ahead and threw together a kit that includes all of the stuff that use ourselves!
This is all you need to reinstall your short block!!!
OUR PRICES CANNOT BE BEAT WITH THESE PARTS!!!
- GMB Water Pump *Pic shows Topline water pump.
- Topline Oil Pump / Front case w/ gears and gasket
- OEM Mitsu Complete Engine Gasket Kit
- Balance Shaft Eliminator Kit
- Power Enterprise Kevlar Timing Belt
- OEM Timing Tensioner
- OEM Tensioner Roller
- OEM Idler Roller
Hey everyone,
At Slowboy Racing, we really do our best to stock the very best in engine internals. We've built hundreds of motors using these very same components so you know they are nothing but the best! I get questions all of the time about combos, which rods with which pistons and so on... I like to make things easy and take all of the guess work out of picking out parts. I've got a few bundles here that will be perfect to just about any power goal! Needless to say, we are by no means limited to these combos!
Kit 1 - CODE 37416
Kit 2 - CODE 37418
[/size][/font]
Kit 3 - CODE 37419
[/size][/font]
I have a lot more options and I'll be updating this quite often! Remember, we're your one stop shop for all internals. 2.0, 2.1, 2.2, 2.3, 2.4 and more!
Marti
mar@slowboyracing.com
AIM: Marti at Slowboy
321-250-4359
Kit 1 - CODE 37416
- Wiseco Forged Pistons (standard or over bore)
- Manley H Beam Rods
- ACL Main Bearings
- ACL Thrust Washers
- ACL Rod Bearings
- Ground Shipping
Kit 2 - CODE 37418
[/size][/font]
- Mahle Forged Pistons (Standard or over bore)
- ACL Main Bearings
- ACL Thrust Bearings
- ACL Rod Bearings
- Ground Shipping
Kit 3 - CODE 37419
[/size][/font]
- Manley Forged Pistons (Standard or over bore)
- ACL Main Bearings
- ACL Rod Bearings
- Ground Shipping
Marti
321-250-4359
These are all journal bearing, the ball bearings will be here in a few weeks.
Heres a list of what we got:
6265SP T3 .82 x1
6262SP T3 .82 x2
6062SP T3 .82 x1
5557 DSM flange w/ Internals x2
PM me or email me for the pricing. AGAIN, these are BILLETT wheel compressor turbos with the port shroud housing.
Joe
jws@slowboyracing.com
6265SP T3 .82 x1
6262SP T3 .82 x2
6062SP T3 .82 x1
Joe
We just got even more great parts in stock from our friends at Manley! The Manley product line offers excellent quality at a great value!
Check out just some of the products that we've got on the shelf!
Manley H Beam Rods
anley "H" Beam connecting rods are manufactured from 4340 forgings to the same exacting standards developed and approved by our original equipment customers. There is a vast difference in quality between a Manley "H" Beam and the "other" inexpensive H-Beams on the market. Weight matched to +/- 1.5 grams. Perfectly round big and small ends. Bend and twist is tightly controlled.
Normally $359 Call me today for a great discounted price!
Manley H Beam w/ ARP625 Bolts
Same great built quality as the H Beam rod but with the addition of ARP 625 rod bolts! This combo stacks up to handle power levels up to 800hp!!!
Normally $600 Call me today about a great discounted price!
Manley I Beam Rods
These rods are rated out of the box at 800 + horsepower and are still 100% streetable. Utilizing the strongest available steel and a proven I-Beam desing, you will not find a stronger streetable rod from anyone. Manley connecting rods are pricey, but that comes with the peace of mind knowing that your bottom end is rock solid!
Normally $750. Call me today for a great discounted price!
Manley Forged Pistons 2.0L and 2.3L
Forgings
- 2618 alloy for maximum high temperature strength and fatigue resistance.
Attributes
- "Contour forgings" provide the optimum balance between strength and weight with no grain-interrupting internal milling.
- Proprietary multi-step top ring groove machining process assures optimum control of the groove's size, geometry, flatness and finish.
- All final turning is performed in one fixturing resulting in complete squareness of rings to the cylinder wall.
- Federal Form-Scan gauging validates ideal skirt indexing to pinhole and skirt-to-skirt polarity.
- Value - added features such as a pressure balance groove included in all series.
- Precise pinhole machining results in an exact compression distance as well as precise lock ring groove spacing, size and concentricity.
Normally $455. Call me today for a great discounted price!
Manley Race / Extreme Valves
Manley valves have set the standard for excellence in quality, material and design in the performance world for four decades. Manufactured from proven Race Master materials, Manley valves feature chrome stems, hard tips, fully machined surfaces and swirl polished radii. Many applications are Pro Flow design for maximum air flow.
Normally starting at only $135 per set! Call me for a great discounted price!
Manley Vale Spring and Retainer Kits!
We've got various options with Manley's kit. We have them in a single or dual spring and also with or without valve locks! Regardless of your setup, we have a Spring and Retainer kit from Manley to meet your needs!
Normally Stating at $249. Call me today for a great discounted price!
Marti
General Manager
Slowboy Racing, Inc
AIM: marti at slowboy
Manley H Beam Rods
Manley I Beam Rods
Forgings
Attributes
Marti
General Manager
Slowboy Racing, Inc
Aem aem aem we will not be undersold!
http://www.slowboystore.com/aem_adva...t/b-10052.aspx
We work very closely with our friends at AEM and we're proud to offer their extensive line of products!
Gauges, tuning tools, injection kit and more! We've got everything from AEM that you need for your build!
We have AEM UEGO & Tru Boost up the ying yang! We've got great prices so let us know how we can earn your business
Product of the Day for AEM WEEK!
AEM UEGO - It has really come to be the staple and standard wideband for the masses. We keep tons in stock to meet your needs and can ship them today! We're a direct authorized distributor so you know you're getting the real thing, with real support and a warranty!
http://www.slowboystore.com/aem_adva...0/i-48045.aspx
WE WILL NOT BE UNDERSOLD!
In continuing with AEM week, I direct your attention to the AEM Tru-Boost.
This boost controller is one of my personal favorites. It's compact design fits in any 52mm gauge pod, comes with harnesses and hardware for a clean install and works very well. It uses an on gauge controlling system that can be set to your desired boost level and has a scramble feature for when you need to go really really fast. :banana: All together you get a great product for a great value.
Check out our site at www.slowboystore.com for this and many other great AEM products that we have available for your project!
