Shearer's Back!
Old Sep 9, 2009 | 08:43 AM
Shearer's Avatar
Originally Posted by chu
Is the 02 dump going to have to be modded for certain licp fitments?
It shouldn't. We tried to think far enough ahead to avoid that. So far it seems to clear everything.
Old Sep 9, 2009 | 06:46 PM
KentStateTsi's Avatar
Veteran: Army
Def. amazing products Ron! Is it possible I could order a 5 bolt O2 with a stock DP flange?
Old Sep 9, 2009 | 07:10 PM
vwjeff's Avatar
For as long as I own an Evo, I will NEVER run anything but your products bud!
Welcome back!
Old Sep 10, 2009 | 07:16 AM
Shearer's Avatar
For our T3 kit I assume? I could but wouldn't be able to do stock location. The turbine housing gets in the way with our T3 kit.
Welcome back!
Thanks yo! That gives me a warm and fuzzy feeling inside.
Old Sep 14, 2009 | 05:18 AM
The-Evo's Avatar
Hey Ron. I just recieved your 02 Dump. It looks awsome and it clears everything with an angled look. I HAD A PROBLEM THOUGH? Its leaking. I used the stock gasket. I dont know if there was suppose to be an updated gasket with my dump, but I need one please? The stock gasket does not cover the holes properly. PLEASE HELP?
Old Sep 14, 2009 | 01:22 PM
Shearer's Avatar
Give me a call when you have an opportunity. Both flanges are machined flat before they leave here to ensure a proper seal. If the gasket isn't covering the holes properly that may be part of the problem, it's hard to tell without more info. We've had people use them without gaskets and they seal just fine.
Old Sep 14, 2009 | 01:25 PM
Import Junky's Avatar
Hey Ron, you should post a thread like AMS did awhile ago called
"What would you like to see from Shearer" or something like that.
Old Sep 15, 2009 | 09:44 AM
Shearer's Avatar
I talked to the guys doing your work last night. The gasket you have has an open passage between the turbine wheel and the wastegate outlet. It was allowing a small leak between the turbine wheel and wastegate. Told them to toss the gasket out and you will be fine.
What would you like to see? If anyone has some ideas post them up.
Old Sep 15, 2009 | 09:55 AM
MR.CT9A's Avatar
a forward facing stock frame manifold would be badass!!!!!
Old Sep 15, 2009 | 06:47 PM
Shearer's Avatar
I think it would be pointless. If you want one though, I'll build ya one.
Old Sep 15, 2009 | 06:49 PM
dmoevo's Avatar
haha that would be pretty neat, I got speed density so why not?
Old Sep 16, 2009 | 03:28 AM
The-Evo's Avatar
Thanks Ron. It worked out great without the gasket. It hasent leaked yet. Hopefully it holds up for the tune in october. I think it should though.
Old Sep 16, 2009 | 01:16 PM
h22gordo's Avatar
Seriously, you have THE nicest fabwork on all of Evom!!
Keep up the great work! Hope to order from you soon!
Old Sep 17, 2009 | 09:27 AM
Shearer's Avatar
Here's something else that might interest you guys...
Small Runner EVO T3 manifold.
blog.shearerfabrications.com
Old Sep 17, 2009 | 09:29 AM
Shearer's Avatar
Thanks dude. We do our best.
