New Products, plates, arms and deletes
We've designed these units a while back and have had them installed on not only the rally cars, our own cars and on numerous street and track prepped weekend warriors.
Going further meant making them dedicated so we did and when pairing them up with the Perrin Zero (or offset for even more caster) offset Anti Lift Kit or Positive Steering Response Kit as they call it. You're able to turn out 6+ degree of caster!!!
Only high quality grade aluminum is used along with the highest quality Aurora bushings.
Did we mention this can be done with a factory strut? This is a single piece CNC unit that can be installed on any strut assembly that accepts the factory strut mount and will be easiest way to get 2+ degree of camber.
These are the cheapest and most cost effective parts that can make a drastic difference to how your vehicle handles. Thinking about the value is why they are so cost effective, no need to get under the car and start messing with the control arm bushings that are most likely seized if your higher mileage with abuse. Simply pull off the strut, take the old top hat off, install the units and you're SET! Instant change.
Anodizing options will be available soon but the images will be reflecting the raw material.
The control arms that we produced are not only meant to be infinitely adjustable, the the location that the bushings are at and the specific design of them allows for the geometry to be setup in such a way that you will have the best suspension travel.
We only utilize Aurora bushings as they are the best on the market, along with SCCA specific, FIA rated bushings allow the rear end to really tighten up
Back to the suspension travel, when used with a coilover or even a factory strut, you won't loose the grip in the rear end because the suspension has maxed out in lift (extension or rebound) thus allowing you to go deeper into the turn in.
Racing specific applications can be made from Rally, Rally Cross, Auto X, Road Racing and even for those who are looking for quality Stance builds
Lets talk some brakes, brakes that work and can retain a consistent pedal feel so that street driving is still acceptable. On top of this, you'll be able to get rid of some weight via the brake booster, ABS pump and hard lines.
The APM Brake Master Delete Kit is the option that can work for you and what you want. We've consistently and deliberately put the brake kit, arms and top hats though it's paces via a local road course and we couldn't be happier.
The pedal feel is stiffer but has great feedback and response while retaining it's ability to modulate properly and be street driven.
-Mark
-Mark
bnr34rb26dett
Sep 30, 2016 09:50 AM
APM Racing
Evo 'For Sale' Services
15
Sep 22, 2011 01:19 PM
APM Racing
Evo 'For Sale' Suspension / Brakes / Handling
20
Jul 22, 2011 10:02 AM
APM Racing
Evo 'For Sale' Engine Internals and Drivetrain
22
Jul 22, 2011 09:58 AM
