Torque Solution New Release Evolution X !!!!
Old Apr 1, 2013 | 08:35 AM
Shaun@AWDMotorsports's Avatar
PM For Pricing
NEW
Torque Solution Billet Shift Knob RED or BLACK
Torque Solution billet shift knobs are machined from 6061 Billet material and hard anodized to resist scratching and wear. Each knob weighs 188g / 6.6oz to give you that more positive & smooth feel when shifting. Suitable for all forms of racing and guaranteed to last a lifetime.
Features
- Installs in Minutes
- Weighs 188g / 6.6oz
- Street and track torture tested
- Hard Anodized
- Lifetime Warranty
- Made in USA
Torque Solution Billet 3" Shifter Extension: Mitsubishi Evo & All Manual Shifters 10x1.25 Thread Pitch
Torque Solution Shifter Extensions are used to raise the gear shift knob to provide a better arm angle for more precise and comfortable shifting. Longer shift levers are commonly used in race applications where every shift matters.
Torque Solution Delrin 50mm Round Shift Knob: Universal 10x1.25
Torque Solution 2" round shift knob is made from an aerospace polymer Delrin material. Delrin material is impervious to heat and cold. Making it an excellent choice for racing applications and for daily driving in hot and cold climates. It is also not slippery and will not rattle like some metal knobs do. The hole extends as deep as possible to give you the lowest possible installed height..
Torque Solution Delrin Tear Drop Shift Knob: Universal 10x1.25
Torque Solution Tear Drop shift knob is made from an aerospace polymer Delrin material. Delrin material is impervious to heat and cold. Making it an excellent choice for racing applications and for daily driving in hot and cold climates. It is also not slippery and will not rattle like some metal knobs do. The hole extends as deep as possible to give you the lowest possible installed height..
Torque Solution O2 Sensor Extender: Universal
On ODB-II vehicles (96+), the ECU has two O2 sensors for diagnostic purposes. The first O2 sensor is located before the Catalytic Converter. This O2 sensor is responsible for all the Air/Fuel tuning and is imperative to the operation of the vehicle.
This Steel O2 sensor extender is basically for keeping the O2 sensor out of exhaust pipe. These also work when running a hi flow cat or a test pipe. It's a very simple 10~15 mins installation, This extender will fit most O2 sensors with 18mm thread size.
Torque Solution Stainless Steel O2 Sensor Bung: Universal
Stainless Steel 18mm X 1.5 Weld-on 02 bung for adding Oxygen sensors to your exhaust.
-304 Stainless Steel
-Life Time Warranty
-Made in USA
Torque Solution Shifter Cable Bushings: Mitsubishi Evolution GSR
Torque Solution continues to push the limits of high performance aftermarket products with our "NEW" Shock Factor Shifter Bushings. Developed to perform under the most extreme conditions, Shock Factor Shifter Bushings bridge the gap between ordinary aluminum, brass, and cheap plastics used in current aftermarket shifter bushings by offering a unique Delrin specifically chosen by Torque Solution engineers to ensure product performance and reliability while drastically reducing shifter end play allowing for crisper, more precise shifts. All this makes it easy for us to stand behind our shifter bushings with a lifetime warranty.
Torque Solution Stock Location Tial Blow off Valve Adapter: Mitsubishi Evolution X 2008+
Torque Solution Billet Stock to Tial Blow off Valve Adapter allows you to direct fit your blow off valve to your Stock flanged piping without any welding.. This is a direct bolt on adapter to allow you to fit a Tial 50mm BOV to your intercooler piping.
Torque Solution Drive Shaft Carrier Bearing Bushings: Amy Mitsubishi Evolution 1992-13
Torque Solution Drive Shaft Center Support Bushings will replace the OEM Rubber mounts with Delrin Polymer pieces. Doing so will allow for reduced wheel hop, improved acceleration and better E.T's. The mounts keep the propeller shaft from moving under hard acceleration, stopping and turning giving you optimal performance 100% of the time.
Torque Solution Silicone Inlet Pipe for 3" FP Turbo: Mitsubishi Evolution X 2008-2013
Torque Solution continues to push the limits of high performance aftermarket products with our 4ply Silicone Turbo Inlet Hose. This hose is designed to work with Forced Performance 3" turbos. Our silicone hose smooths the air entering the turbo which allows you to make more power. The inlet is 3" which opens up to 3.5" inches to maximize intake volume and velocity with this tapered design. Made from Lifetime Warranty 4ply silicone chosen specifically by Torque Solution engineers for this application so you can be sure it will perform!!
Torque Solution Gate Selector Pivot Bushing: Mitsubishi Evolution X 2008+
Torque Solution Gate Selector Pivot Bushing eliminates much of the shifter play felt on the Evo X models. Giving you a more precise feel in between gear changes. Get rid of that sloppy and less than direct feeling the Evo X has with this Delrin 2pc replacement kit
Torque Solution Exhaust Mount kit: Mitsubishi Evolution X 2008-11
Direct Replacement
Torque Solution exhaust mounts will reduce exhaust movement and vibrations both under extreme racing conditions and daily street driving. Great compliment to any exhaust kits.
Torque Solution Super Shorty 2" Billet Antenna: Mitsubishi Evolution X 2008+
Replace your long factory antenna with our billet shorty antenna, Giving you a new style to your car.
- 2" inch Tall
- Installs in under 2 minutes
- Made out of lightweight 6061-T6 billet aluminum
- Black anodized
- Lifetime Warranty
- Made in USA
Torque Solution Short Shifter: Mitsubishi Evolution X 2008-12
Torque Solution short throw shifter is a direct replacement for your long throw stock unit.Our shifters are made from 4130 Chromoly steel and are Cnc machined to precision tolerances .After this they are set out to be chrome plated to last a lifetime.This is the best mod for your ride.
Torque Solution Shifter Base Bushing Kit: Mitsubishi Evo X 2008-12
Torque Solution shifter base bushing kit replaces the OEM rubber bushings on the bottom of the shifter providing a more stable shifter platform and mounting points.
Torque Solution EVO X Fuel Pump Holder: Mitsubishi Lancer Evolution GSR & MR 2008+
Run out of Fuel on your Evo X and need more fuel pump?? Here is the answer to your fuel issues..
We have designed a 6061 Billet Fuel Pump Holder to accept Walbro 255lph pumps along with Aeromotive, Deatschwerks, and FullBlown 340lph Pumps..
The 340LPH fuel pumps will give you enough fuel to make over 500whp on your Evo X w/ E85. Plenty for stock motor applications.. These are all E85 Compatible..
This kit Includes the Following: Pump Holder, Flexible Hose, Filter & Set Screws to hold pump in place..
Torque Solution Solid Differential Side Inserts: Mitsubishi Evolution X MR & GSR 2008+
These 6061 Solid Billet bushings are much harder compared to the OEM units. By replacing them with these Solid Billet Inserts you are able to get rid of the unwanted slop and flexing of the stock units which allows for the power to go into rotating the tires, instead of flexing the rubber. Giving you better feedback, sharper response, more predictability on throttle input, along with eliminating annoying clunking during hard shifts.
The solid differential mount will eliminate movement of the rear end in the subframe. By replacing the rubber mount with this solid 6061 billet unit you are able to get rid of the unwanted slop and flexing of the stock units which allows for the power to go into rotating the tires, instead of flexing the rubber. Giving you better feedback, sharper response, more predictability on throttle input, along with eliminating annoying clunking during hard shifts.
Torque Solution Urethane Differential Inserts: Mitsubishi Evolution X MR & GSR 2008+
These Solid Polyurethane bushings are much harder compared to the OEM units. By replacing them with these harder Polyurethane units you are able to get rid of the unwanted slop and flexing of the stock units which allows for the power to go into rotating the tires, instead of flexing the rubber. Giving you better feedback, sharper response, more predictability on throttle input, along with eliminating annoying clunking during hard shifts.
Torque Solution Solid Differential Bushing w/ Billet Inserts: Mitsubishi Evolution X MR & GSR 2008+
Old Apr 2, 2013 | 10:07 AM
ttt
Old Apr 5, 2013 | 09:29 AM
bump
Old Apr 9, 2013 | 10:26 AM
ttt
Old Apr 12, 2013 | 11:15 AM
bump
Old Apr 16, 2013 | 01:11 PM
ttt
Old Apr 19, 2013 | 12:35 PM
bump
Old Apr 23, 2013 | 09:46 AM
Send over a PM to get FREE SHIPPING!!!
Old Apr 26, 2013 | 12:09 PM
ttt
Old May 1, 2013 | 10:11 AM
bump
Old May 9, 2013 | 10:56 AM
ttt
Old May 15, 2013 | 11:31 AM
bump
Old May 21, 2013 | 02:54 PM
ttt
Old May 28, 2013 | 12:03 PM
bump
Old May 31, 2013 | 02:57 PM
ttt
