Evo X Throttle Body Upgrade / Porting services now available!
Evolution 10 Throttle Body Upgrades are now being offered by your favorite Evo X performance shop! Get a 64mm ported Evo 10 throttle body today!
Evo X throttle body upgrades are the best way to pull every last bit of power from your aftermarket or stock Evo 10 induction system, and a great compliment to our stock frame EF Series Turbo's. Our research and development team has worked hard perfecting our port and polishing techniques especially for this Evo X throttle body to bring you the best Evo 10 throttle body upgrade possible!
First, we took a stock Evolution 10 throttle body and prepped it for our Evo X throttle body upgrade by pulling out the factory throttle plate. This allows us to port it open to a free-flowing 64mm before putting in an upgraded stainless steel butterfly plate. We then took it to our assembly room, where we made sure it retained all factory features, including the Idle Air Control valve and accessory ports.
Looking for the most performance alongside this Evo X throttle body upgrade? Check out our Rev 2 and Rev 3 intake manifolds, which allow for better throttle response across all RPM ranges and boost pressures, and have proven to improve CFM's and in turn, add more power!
All that's required in getting setup with an upgraded Evo X throttle body is a core unit. You can either send us your factory throttle body for the upgrade, or take advantage of the MAP core program, which charges a $400 core fee. This charge is refunded when we receive your used throttle body. The core program is great for daily driven Evo 10's, where downtime is not an option.
maperformance
179
Mar 6, 2015 07:35 AM
maperformance
Mar 6, 2015 07:29 AM
maperformance
11
Aug 24, 2011 11:58 PM
