Introducing the FP Zero and Zephyr.
Old Aug 27, 2014 | 07:48 AM
Michael @ FP's Avatar
These two new turbochargers represent the most recent evolution of our direct fit style turbos for the Lancer EVO4-9. These 2 units answer the call for improved performance at higher boost pressure and flow rates.
They debut our release of the new Xona Series CHRA which are a billet SS construction featuring expanded water jacketing which fully surround the entire hot side register for improved heat blocking in the turbine section. Better materials extend the service life through improved corrosion resistance and reduced heat conduction into the bearing section of the CHRA. The rotating assembly is isolated from vibration 3 dimensionally via specially designed oil damping chambers which also serve to provide variable preload to the angular contact ceramic ball bearings ensuring that bearing preload increases with oil pressure, rpm and thrust loads a feature never before seen in ball bearing turbochargers. Correct loading of angular contact ball bearings and bearing temperature are the determining factors when it comes to the lifespan of the ball bearing. The features do not end there.
The aeros selected for these two new units are also very impressive. The 79HTZ and the 86HTZ both represent the newest evolution of our billet compressor wheels that have defined aftermarket turbocharging since our release of billet compressor wheels in 2007. Flowing 65lb/min and 75lb/min respectively and allowing PR as high as 5:1, these new aeros deliver perfectly matched flow for your 650HP and 750HP high pressure ratio 4G63 applications. Couple this with the enlarged high pressure ratio turbine wheel which is 68/62mm vs the 67/59mm found in our Green, Red and Black models and you have made to order domination over stock appearing performance classes in both 650HP and 750HP sizes.
The turbine housings used for these models are equally impressive. Constructed in special high strength Stainless steel (more than twice as strong as 304SS at operating temperatures) they can survive thousands of hours at steady state 1700F+ temperatures. The use an integrated external TiAl MVS wastegate for boost control eliminating one of the inherent shortcomings of the earlier generation turbos which was the flapper valve and actuator assembly. The housing is a 10.5cm2 nozzle without a divider wall to reduce the pumping loss thru the turbine section of the turbo. This comes at a slight loss of part throttle boost response below 4500rpm, but is all part of hitting these higher power numbers and creating an efficient high boost turbocharger for the 4G63.
The compressor housings feature large volume open Flow Advancement Ports like previous generations. This opens style port, the FAP, style is a large benefit to dealing with low flow/high pressure ratio compressor instability as well and increasing high flow/ high pressure ratio choke flow by feeding the splitter blades directly something that bullet holes cannot achieve.
These turbos represent our best work to date.
These turbos are approved for use in the Stock Appearing Class at the 2015 Buschur Racing Shootout.
Old Aug 27, 2014 | 07:55 AM
escodotcarter's Avatar
impressive
Old Aug 27, 2014 | 08:34 AM
JohnBradley's Avatar
Looking good.
Old Aug 27, 2014 | 11:46 AM
SWOLN's Avatar
It's a long shot, but dyno chart?
Old Aug 27, 2014 | 12:25 PM
balls_deep_evo's Avatar
I see that the zephyrs flow is rated lower than the black 65lb/68lb but how much faster does it spool?
Old Aug 27, 2014 | 12:41 PM
mkcolgan's Avatar
In for a dyno plot/mod list as well!
Old Aug 27, 2014 | 01:55 PM
gsrboi80's Avatar
Very nice!!
Not a stock replacement/appearing turbo IMO but very nice none the less.
Looking forward to riding in a car with one
Old Aug 27, 2014 | 02:41 PM
doober's Avatar
I love Nate's response in that video. Wasn't the prototype one on that car the old turbine housing? I forget off hand.
Awesome stuff though guys! Can't wait to try out the zero here next time around. Should make for a fun time on a stoker.
Old Aug 27, 2014 | 02:43 PM
krisdlm's Avatar
sub'd! I would love to see a fp black / fp zero comparison
Old Aug 27, 2014 | 03:57 PM
mitsubeastlee's Avatar
impressive. use all this tech on your non stock frame stuff...
Old Aug 27, 2014 | 09:40 PM
slowsrt4:('s Avatar
glad you got these bad boys approved for the stock appearance class for the shootout, did you guys bribe Buschur with a few "test" models lol. But seriously, it is always great to see that new parts are being made for these cars even with their age.
Old Aug 27, 2014 | 11:00 PM
Grimgrak's Avatar
So no twin scroll?
Old Aug 27, 2014 | 11:54 PM
DsmGuy86's Avatar
Finally.. I've been waiting so long for these. In for results starting a new build this winter and I held off on turbos until I've seen what these can do
Old Aug 28, 2014 | 04:44 AM
RLLN247's Avatar
With the new housings i think there is a loss of spool.
Old Aug 28, 2014 | 06:33 AM
sparky's Avatar
Mike: Dumb question I know....but these two new turbos bolt up directly to stock exhaust manifold?
