Victory Function VF-02 CFRP
Nice! Do you have anything in the works for guys/gals running a more aggressive setup? 18x10-10.5 wheel, 0 - +22 offset running 275/35 or 285-295/30 tire.
You would have to do 2 things.. trim the inner arch of our sweep about a 1/8 inch. Also this tire size will rub the inside corner of the front of the oem sideskirt - so a slight shave there too
And you will need to shim the front bumper/fender connection w/ a 5-8mm spacer,
Our FRP does have some inherit flex to it, not much - but enough for this amount.
The bottom of the fender/sideskirt end cap actually serves a a great deflector for the majority of the debris.
One of our VF-02 owners is more than welcome to chime in here.
