Aeromotive 340 Stealth E85 Fuel Pump!
The Aeromotive 340 Stealth Fuel Pump is a high-output, in-tank, electric fuel pump that fits most popular EFI applications. The Aeromotive 340 is a compact, lightweight pump that bolts into many existing hanger assemblies.
What sets the 340 Stealth Pump apart is its superior flow throughout a wide pressure range. Compared to other popular aftermarket pumps, at 40 psi the 340 boasts more than 340 lph. That's over 30% more flow. This pump is ideal for applications requiring more flow while retaining the factory lines and mounting provisions available in the Original Equipment (O.E.) configuration. The 340 is also perfect for use as a universal replacement for applications that require more flow to support forced air power adders such as turbo and supercharged applications.
• P/N 11540
• Fits most vehicles where popular aftermarket pumps are applicable
• Center Inlet
• E85 Compatible
• Includes universal filter sock - may not fit in some applications (see OEM filter replacement recommendations)
• Designed for in-tank use only
• Can be used in Carbureted or EFI applications
• Turbine pump mechanism increases durability and can be used in pulse modulated applications.
P/N 11540 Includes:
• Pump
• Universal Drop Parts Kit (Filter, Wiring Pigtail, Rubber Hose, (2) Clamps, Rubber Grommet)
Order yours for only $112.14
The 11542 pump is stock fitment into an Evo IX ( https://www.extremepsi.com/store/pro...7&cat=0&page=1 ). It will generally support around 400whp although its very dependent on things like fuel type, injector size and fuel pressure.
If you're looking to go beyond that power level, we recommend the Walbro 450 which is semi-drop in. It does require some modification to the hanger to fit. https://www.extremepsi.com/store/pro...roductid=30208
I was looking into this pump and noticed there are some special notes for use on an evo in their application guide. Is there a reason for this?
https://www.aeromotiveinc.com/wp-con...tion_guide.pdf
whiteEvo08Y
Mar 11, 2017 02:10 PM
RallySport Direct
18
Aug 27, 2014 02:52 PM
RallySport Direct
EvoX 'For Sale' External Engine / Power
21
Aug 18, 2014 11:05 AM
Scottr126
Automotosports - Illinois
61
Mar 27, 2012 03:05 PM
