-   Vendor Announcements (https://www.evolutionm.net/forums/vendor-announcements-235/)
-   -   STM's Redesigned Evo oil cooler kit! (https://www.evolutionm.net/forums/vendor-announcements/463518-stms-redesigned-evo-oil-cooler-kit.html)
EmeryatSTM Dec 14, 2009 08:34 PM
So after a lot of debate and some customers having issues installing our old kits we decided to make it as easy as possible without changing the price. Our kits now come with russell pro classic instead of the pain in the a$$ SS hose. It is very easy to work with and makes the install a breeze. Anyone who has blown a motor MUST replace their oil cooler and this is a cheap reliable setup. We even run it in our car!
On to the pics.
http://www.streettunedmotorsports.co...proclassic.jpg
installed on our car
http://www.streettunedmotorsports.co...roclassic2.jpg
http://www.streettunedmotorsports.co...roclassic3.jpg
http://www.streettunedmotorsports.co...roclassic4.jpg
And hose instructions
http://www.streettunedmotorsports.co...c_assembly.jpg
Although this is a very easy kit to install you still need to have some sort of do it yourself mentality as it requires you to make some sort of bracket.
These kits can be found here.
http://www.streettunedmotorsports.co...evo_engine.htm
Thank you for your cotinued support!
-STM
David24 Dec 14, 2009 08:43 PM
So does this bolt on exactly where the stock one was? I'm in need of an oil cooler due to an engine failure and this one fits my budget if it is equal or better then stock. Thanks!
EmeryatSTM Dec 14, 2009 08:51 PM
It will fit in place but you will need to make a bracket to hold it. ITs a fairly easy install though.
As far as it being better than stock, It does have 13 more cooling rows but I do not have before and after testing data.
-Em
CBRD Dec 15, 2009 07:04 AM
Emery,
have you considered flipping it vertical, I never liked placing the fittings as the lowest point, im sure you can just make another bracket..
nice choice on the lines and ends!!
cb
NickieBlaine Dec 15, 2009 07:16 AM
Originally Posted by CBRD (Post 7800546)
Emery,
cb
any particular reason?
Any pictures of mounting bracket?
EmeryatSTM Dec 15, 2009 09:18 AM
Emery,
cb
You could mount it that way but I didn't see a reason to in our application. The fittings still sit very high and I don't see it being a problem.
-Em
EmeryatSTM Dec 15, 2009 09:21 AM
For the mounting bracket we used a piece of aluminum stock from Home depot and drilled a few holes in it to attach it to the car and cooler. Very simple. I will see if I can get plcs later for you.
-Em
CBRD Dec 15, 2009 09:28 AM
-Em
Em,
looks good.... i couldnt tell from the pics where it sat...
cheers
cb
EmeryatSTM Dec 15, 2009 02:59 PM
Thanks!
-Em
hamx0r Dec 15, 2009 04:12 PM
bump for STM... ordered one today, cant wait to get it in to finish up my car.
EmeryatSTM Dec 17, 2009 06:58 PM
Thanks for your support.
-Em
binh Dec 28, 2009 12:38 PM
-Em
Can you get a picture of this? thanks!
EmeryatSTM Dec 28, 2009 02:20 PM
Sorry for the wait.
http://www.streettunedmotorsports.co...il_cooler1.jpg
http://www.streettunedmotorsports.co...il_cooler2.jpg
http://www.streettunedmotorsports.co...il_cooler3.jpg
-Em
Gary@MellonRacing Dec 28, 2009 05:10 PM
clean clean , liked it
Evokid03 Dec 28, 2009 07:26 PM
looks like ill be ordering one soon :)
