STM's Redesigned Evo oil cooler kit!
Old Dec 14, 2009 | 08:34 PM
EmeryatSTM's Avatar
So after a lot of debate and some customers having issues installing our old kits we decided to make it as easy as possible without changing the price. Our kits now come with russell pro classic instead of the pain in the a$$ SS hose. It is very easy to work with and makes the install a breeze. Anyone who has blown a motor MUST replace their oil cooler and this is a cheap reliable setup. We even run it in our car!
On to the pics.
installed on our car
And hose instructions
Although this is a very easy kit to install you still need to have some sort of do it yourself mentality as it requires you to make some sort of bracket.
These kits can be found here.
http://www.streettunedmotorsports.co...evo_engine.htm
Thank you for your cotinued support!
-STM
Old Dec 14, 2009 | 08:43 PM
David24's Avatar
So does this bolt on exactly where the stock one was? I'm in need of an oil cooler due to an engine failure and this one fits my budget if it is equal or better then stock. Thanks!
Old Dec 14, 2009 | 08:51 PM
EmeryatSTM's Avatar
It will fit in place but you will need to make a bracket to hold it. ITs a fairly easy install though.
As far as it being better than stock, It does have 13 more cooling rows but I do not have before and after testing data.
-Em
Old Dec 15, 2009 | 07:04 AM
CBRD's Avatar
Emery,
have you considered flipping it vertical, I never liked placing the fittings as the lowest point, im sure you can just make another bracket..
nice choice on the lines and ends!!
cb
Old Dec 15, 2009 | 07:16 AM
NickieBlaine's Avatar
Originally Posted by CBRD
Emery,
cb
any particular reason?
Any pictures of mounting bracket?
Old Dec 15, 2009 | 09:18 AM
EmeryatSTM's Avatar
Emery,
cb
You could mount it that way but I didn't see a reason to in our application. The fittings still sit very high and I don't see it being a problem.
-Em
Old Dec 15, 2009 | 09:21 AM
EmeryatSTM's Avatar
For the mounting bracket we used a piece of aluminum stock from Home depot and drilled a few holes in it to attach it to the car and cooler. Very simple. I will see if I can get plcs later for you.
-Em
Old Dec 15, 2009 | 09:28 AM
CBRD's Avatar
-Em
Em,
looks good.... i couldnt tell from the pics where it sat...
cheers
cb
Old Dec 15, 2009 | 02:59 PM
EmeryatSTM's Avatar
Thanks!
-Em
Old Dec 15, 2009 | 04:12 PM
hamx0r's Avatar
bump for STM... ordered one today, cant wait to get it in to finish up my car.
Old Dec 17, 2009 | 06:58 PM
EmeryatSTM's Avatar
Thanks for your support.
-Em
Old Dec 28, 2009 | 12:38 PM
binh's Avatar
-Em
Can you get a picture of this? thanks!
Old Dec 28, 2009 | 02:20 PM
EmeryatSTM's Avatar
Sorry for the wait.
-Em
Old Dec 28, 2009 | 05:10 PM
Gary@MellonRacing's Avatar
clean clean , liked it
Old Dec 28, 2009 | 07:26 PM
Evokid03's Avatar
looks like ill be ordering one soon
