NLR Boost Controllers at Extreme PSI
Extreme PSI now offers NLR Boost Controllers
Are you ready for the best boost controller on the market? The same boost controller that many of the top race teams run? Well now you can get it at Extreme PSI. The NLR AMS 1000 and AMS 500 are the two baddest boost controllers out there.
Here are just some of the features of the AMS 1000:
- Time Based One to six timed stages are available with this mode of operation. Each stage has an adjustable timer to control the duration. The Ramp Rate (rate at which the pressure is applied) is adjustable from 0 to 100 psi per second. A Ramp Rate setting of 0 does not disable the stage. The target psi will instantly rise at the end of any timed stage with a 0 Ramp Rate setting. The target psi can be increased or decreased over time to achieve the desired Boost Profile.
- Shift Based One to six stages are available and are controlled by a shift-input signal. The Ramp Rate for each stage is programmable as well as the Target psi for each stage (gear position). The Ramp Rate settings perform the same functions as in Time Based mode.
- GPS Based One to six stages are available and are controlled by a 0-5 volt analog Input signal. This mode is for newer sport bikes or any vehicle that produces a different voltage for each gear position. A switch that produces a different voltage for each position can be used to select different boost profiles (up to six) on vehicles that do not use a Gear Position Sensor system. The Ramp Rate for each stage is programmable as well as the Target psi for each stage (gear position). The Ramp Rate settings perform the same functions as in Time Based Mode. Data logging is NOT available with this mode of operation.
Here is a quick summary of the AMS 500:
The AMS-500 Boost Controller was designed as a street/strip controller for those who do not need all the bells and whistles of the AMS-1000. It uses the same control logic so control is the same as the AMS-1000 unit. The AMS-500 offers 2 stages of wastegate control and uses a internal 40 psi pressure sensor. Don't be fooled, this is the most advanced 2 stage controller out there offering 3 modes of operation.
Thanks,
Tony
www.ExtremePSI.com
1-800-PSI-4502
215-244-4295
sales@extremepsi.com
