Xede timing Q
Old Sep 28, 2004 | 11:18 AM
Jorge T's Avatar
Xede timing Q
Does retarding -.5 deg on the timing table takes out -.5 deg of spark advance or -1 deg of spark advance?
Old Sep 28, 2004 | 03:16 PM
BJai02's Avatar
I am not sure what you are asking, if you put -0.5 in a cell, it ECU will run the ECU's preferred timing - 0.5 degree. That means if your ECU wants to run 16 deg, XEDE will modify the signal and have run it at 15.5 deg.
Hope it helps.
Old Sep 28, 2004 | 04:09 PM
Jorge T's Avatar
Thanks, that was along the lines I was asking. Someone told me it was double the value you entered in the cell. If you entered -.5 the actual change was -1.
Old Sep 28, 2004 | 04:13 PM
David@Vishnu's Avatar
no other poster is right
