Reflash and MBC??
Old Oct 5, 2004 | 05:51 AM
Hooligan317's Avatar
Reflash and MBC??
Hey guys, I currently have the cannonball flash and am looking to make sure that I can use an MBC to turn up the boost w/o having any problems due to the fash. Any help would be appreciated. Thanks!
-Matt
Old Oct 5, 2004 | 06:39 AM
Eric Lyublinsky's Avatar
-Matt
Matt with the cannonball flash it's really designed to be used with the stock boost curve. By adding a MBC even at the same peak boost level the boost will be higher at the uppper rpm range witch would mean that it's tuned for lower boost. If you add a MBC the boost would be higher at those ranges and you might lose power because of knock attivatiy witch the computer will see and pull timing. If you would like to run more boost then I would suggest getting a Xflash that maches your mods.
Bottom line you might lose power up top with more boost.
My Best
Eric
Old Oct 5, 2004 | 07:35 AM
Thanks Eric!
Old Oct 6, 2004 | 10:04 AM
TurboFabie's Avatar
can anyone tell me what maximum but safe boost level to run with a MBC using stock ecu? thanks, Daniel
