300whp Goal Plz Help!!
Old Oct 5, 2004 | 09:14 AM
RenoEvo's Avatar
Exclamation 300whp Goal Plz Help!!
A friend of mine dynoed 263whp/260 tq. on a DD dyno on stock boost. His power mods are: Borla Turboback, UTEC, HKS 264/272, HKS cam gears, and a walbro fuel pump. He said he wants to reach 300whp on 91 octane and I told him he should turn the boost up to about 21psi and he'd probably be almost there, somewhere in the 280's. But then he was saying he doesn't want to turn the boost up because it'll mess up his A/F ratios and risk "blowing up his engine" and also saying he's already maxing the stock injectors and gets consistent fuel cut. I know a lot of you guys are near 300whp on 91 octane at about 21psi so basically he's full of it. I know he's not maxing the stock injectors and I know there's a lot of evo's out there SAFELY pushing to 21-22psi w/o fuel cut. Can I get some advice on what to tell him (you guys know a lot more than me) and how he can accomplish his goal of 300whp on the stock turbo, injectors, and FMIC
thanks
Old Oct 5, 2004 | 09:35 AM
snoop's Avatar
thanks
263whp/260 tq. on a DD dyno is 310WHP on Dynojet. He already has 300WHP
If he wants 300WHP on DD than he really wants about 350WHP.
Old Oct 5, 2004 | 09:37 AM
RenoEvo's Avatar
Yeah he wants 300 on a DD
Old Oct 5, 2004 | 09:40 AM
MBGSTI's Avatar
300hp on a DD on 91 with stock boost and stock FMIC and stock turbo =Dreamland
unless he wants to buy a stroker kit, port the head, get a better intake manifold etc...
Old Oct 5, 2004 | 09:44 AM
snoop's Avatar
1. EVO8 10.5 CM2 TH (10.5cm^2 Turbine housing) from Forced Perfomance
2.XEDE
3.SHIV custom tune
This will give him 300WHP on the DD
Old Oct 5, 2004 | 09:46 AM
93civEJ1's Avatar
Originally Posted by MBGSTI
300hp on a DD on 91 with stock boost and FMIC and turbo=Dreamland
no way, the stage 3 guys were on stock intercooler this weekend putting down impressive numbers on the DD.
Old Oct 5, 2004 | 09:48 AM
Toddevo 8's Avatar
I run 22-23 lbs of boost all day long. no problems for over 20,000 miles.
MBGSTI's Avatar
2.XEDE
3.SHIV custom tune
Remember the guy said STOCK BOOST and TURBO....thats the key point...with no extra boost...
Sure u can push a stock turbo to 340 on a DD, as my brother evotomig has , but thats not ??? the guy was askin.
Old Oct 5, 2004 | 09:51 AM
David@Vishnu's Avatar
2.XEDE
3.SHIV custom tune
Correct Snoop though on 91 I feel 290 or so is right and safe. Possibly 300 but CA 91 is like other states 89 oct . If his IDCs are nearing max he is running WAY too much timing we are still fully in control of IDCs with and Exhaust (even catless), cams, gears, 10.5 hotside and Xede. The static timing he chooses to run is always going to put him tring for a "best fit approach" for safe operation on a daily basis. Better carry that laptop around
IE Evo's Avatar
Meth/water injection kit and a lil more tuning. Also what do stock Evos Dyno where he had his car dynoed. Not all DD dynos are the same.IMO His goal on 91 oct with the stock turbo is a lil optimistic if this dyno in question reads as low as Shiv's. Some goals that people make are plain stupid and not well thought out. But I could be wrong because I am human. OUT!
Old Oct 5, 2004 | 09:52 AM
Possibly he could too but you guys got racegas at the pump compared to us
Old Oct 5, 2004 | 09:55 AM
RenoEvo's Avatar
He's saying that running over stock boost isn't safe and he's getting fuel cut and maxing the injectors. I just need some help convincing him he's full of it.
Old Oct 5, 2004 | 09:56 AM
RenoEvo's Avatar
BTW, he dynoed somewhere in the bay area and it may have been a mustang dyno and not a DD. It was either at GB or gruppe s
Old Oct 5, 2004 | 09:57 AM
MBGSTI's Avatar
Agreed ....forest
IE did u know Shiv toke ur yellow evo to india???...i saw it on the boat...i swear
Old Oct 5, 2004 | 10:01 AM
RenoEvo's Avatar
how can I convince him that 21psi is safe. he even has a new head gasket and ARP head studs and he thinks he's gonna blow if he turns the boost up a couple lbs. Alos, how the hell would he be getting fuel cut and maxing the stock injectors?
