lifter noise when engine cold? 264/272 cams
I get lifter "tick" noise when the engine is cold w/HKS 264/272 cams. The noise goes away when engine warms up.
Cams were professionally installed, used assembly lube, torqued to specs, etc. We noticed the lifter noise from 1st start up, also noticed it goes away when engine warms up.
Is this normal? Anyone else with this symptom?
From: Work - New York, Alaska, Mexico or the Caribbean. -Home - Tx Hill Country
I'm not sure if you saw this, but here is a similar thread.
https://www.evolutionm.net/forums/sh...threadid=99951
Same here...been that way since day one. Talk to Darkhorse (I think that's his name) he recomends doing a valve job too because of the increased lift and poor seating (If I remember correctly). He has had some really good turnouts from what I know of...but I don't frequent the boards as much as I used to
Its common i had the same thing. The DSM's had it for ever. Mitsu said that they redesigned the lifters but it still happens. When i rebuilt my engine i clean the lifters out with diesal and you wouldnt believe what came out. NASTY! Anyway got them all clean and now they are quiet once agian.
CHris
CHris
