Remove Xede for P0300 Reflash?
I put in a resonated test pipe last week, and coincidentaly or not I'm now getting a p0300 code along with a nasty misfire while crusing @2500/3000 rpm.
I'm going to be taking my car to the dealer in the next few days for a reflash, do I need to remove the Xede. The service manager is cool so i'm not worried about getting voided, I'm concerned about messiong up the Xede when they reflash it.
The reflash for p0300 only works at idle, which is not where the problem is being caused. If you do the reflash, your ecu will undergo great data bank changes. This obviously makes reflashing the ECU much more difficult. I would personaly stay away from the "fix."
I dropped my car off at the dealer and the tech just called me. He was very cool and said the last car they had in with the problem had an Xede and it turned out to be a short in the unit (which Vishnu fixed when they sent it in). When I pick my car up I'm going to try re-loading the map... and take it from there.
Originally Posted by Dyno4mance
This "fix" will do nothing exept give you a heap of problems....DO NOT GET THE P0300 REFLASH from the dealer...my 2c
Do you mind elaborating on this? I'm super confused why Dustin and now Dyno4mance are not recommending a Mistu reflash.
