MAP Switching
Old Oct 26, 2004 | 10:07 AM
UncleXSO's Avatar
Question MAP Switching
Hey all,
Quick questions on the Xede and its MAP switching function. I understand that when the 2 wires in question are separated that the Xede defaults to the primary MAP (93 octane in my case). When Vishnu sent the Xede to me a secondary MAP (100 octane) was downloaded. I also understand that when these wires are connected it should switch to the secondary MAP.
1) What I don't understand though is how will I know which MAP I am in when I put a toggle switch between the 2 wires since the LED will be green for both sides of the toggle?
2) Also, in a related question does anyone know of a safe, reliable octane booster to get to 100 octane from 93?
Thanks
Old Oct 26, 2004 | 10:11 AM
cjb's Avatar
cjb
I'd like to add to this, can you change maps while the car is running?
-CJ
Old Oct 26, 2004 | 10:18 AM
Dyno4mance's Avatar
you can change maps while car is running
Get a toggle switch that is either closed or open...when it is open it is on the pump gas and when closed it is on race and so on....I position a toggle so in the "UP" position it is logical to the idea of "UPPING" power
You can use Xylene to raise octane, but I would not rely on the Octane being a true 100oct
Regards
Andrew
Old Oct 26, 2004 | 10:21 AM
Az3ar's Avatar
Originally Posted by UncleXSO
Hey all,
Thanks
In my case when the wires are disconnected it means map number 1 which is 91 gas and when the wires are connected it means map number 2 which is my race map.
About the gas your booster will be straight 100 octane from the gas station .
Old Oct 26, 2004 | 10:27 AM
UncleXSO's Avatar
Ahhh! Ok. The switch thing makes alot more sense now.
I knew the 100 octane at the stations was the way to go I was just hoping there would be a more convenient way then having to fill a couple gas cans, haul it home, get a funnel....I know, I know I'm whining. Seriously though! Thanks for the tips guys.
Old Oct 27, 2004 | 12:23 PM
kdogg's Avatar
I know there's an LED on the Xede to indicate which map is "on". Is there a way to "extend" that LED to mount next to toggle switch?
Old Oct 27, 2004 | 06:43 PM
Jorge T's Avatar
This is how I did mine white(i did not have red paint handy) is slow, green is GO.
