Winter Air and Tuning?
(Posted here in case others have interest)
Shiv-ites:
Winter's about to show her teeth now and it's almost time to mount the snow tires (yes, the Evo's wonderful as a winter car with the right rubber.) But this is the first winter with Stage 1. So, is there any issue with the custom tune I have now (from Andrew's Shivarama this Fall) and very cold air? I was thinking how increased air density could change the A/F ratio. But I'm just a simple country doc and wanted to ask the sages of the left coast...
Thanks,
Doug in Cincinnati
'03 Stage 1
Shiv-ites:
Thanks,
Doug in Cincinnati
'03 Stage 1
I'm curious on the same question too. Right now w/ it being 58 degrees F outside, in 5th gear at WOT, im hitting and holding 24psi. Custom tuned too. Thank goodness for those ARP head bolts.. its only going to get colder
^^ Ditto.
As for tires, I will be going with the Continental Extreme Contact tires. There are probably better dedicated snow tires, but IMO we don't get enough actual snow around IL to make it worth getting dedicated snow tires. The Contis have gotten pretty good reviews for both snow and other condiditions ... guess I'll find out soon enough how they will work out.
l8r)
l8r)
I put on the Yokohama H-rates series tires. THey are supposedly better than Blizzak's and they fit the same specifications as our stock Evo tires. 17x8.5 They are outstanding. I used them last year. great grip, did excellent in the snow. They work fine on dry roads you just can't corner as well in them.....but they are great snow tires. spent about $1000 on them.
Shiv
Originally Posted by shiv@vishnu
Are you running an XEDE or XFlash?
Shiv
Shiv
The boost tapers as normal throughout the RPM range. In 5th though it holds 24 for a few seconds before tapering off as normal. I only observe this though when going WOT in the 4th and 5th gears. When accelerating from 1st up, it hits about 22-23 for a sec or two.
It was hitting about the same boost though the day being tuned. Noticed it on the drive home. Sounds and runs solid.
ALRIGHTY THEN, LET'S TRY AND GET THIS PUPPY BACK ON COURSE....
Those that have a problem at californian temps or at baseline, start your own thread.
Those curious about winter rubber, I chose Blizzak LM22 as high quality snow/ice with sports handling. If I didn't want the handling, I'd go with classic blizzaks. I put them on the stock wheels and put the Advans on SR22's, which look great and are strong enough for Cincinnati roads. They served well last winter and had good performance on the occasional dry days warm enough for traction. Good in rain, too. Neal@tirerack.com is enormously helpful and a car feak, too.
NOW , the question was whether arctic air is a problem with a Vishnu tuned car. Specs, if useful, Stage 1 with xflash custom tuned at Dyno4mance with installation of boost bleeder.
So, with denser air, will I have a problem with Air/Fuel ratio, boost pressure, or anything?
Thanks, all.
Doug in Cincinnati
Thanks, all.
Doug in Cincinnati
Thanks, all.
Doug in Cincinnati
Thanks, all.
Doug in Cincinnati
If you had a stand-alone ECU, I'd say yes. But you don't. So you have nothing to worry about. Temp compensations are still in effect and totally capable of keeping things in order.
And, until I get a chance to put everything down, for the non-fanatic who wants a fast Evo: Stage 1 Vishnu, ss brakelines, and rear swaybar.
Priceless.
Doug in Cincinnati
