Dyno4mance and vishnu.....graphs
Old Nov 12, 2004 | 08:38 AM
  #31
Dyno4mance's Avatar
and by centerline you mean on the scale? like the 0 setting?
Yes exactly.....
  #32
gsujeff55's Avatar
andrew, don't you want to send me your tension tool so i can do the install tomorrow. it should be overnight ground from atl to statesboro. LOL
Old Nov 12, 2004 | 08:40 AM
  #33
Dyno4mance's Avatar
No I want you to drive to me so I can install your gears for you and charge you for the labor......ya know thats what we do here
Old Nov 12, 2004 | 08:44 AM
  #34
gsujeff55's Avatar
lol. that would cost me say...45-50 for gas just to get there and back...not to mention your 5,000 an hour...LOL.
i will be up there after i get my xede and a few other things to let you and your expertise fine tune my car.
Old Nov 12, 2004 | 10:22 AM
  #35
Dyno4mance's Avatar
Originally Posted by David@Vishnu
Darn good Job Andrew without a xedeflash!! nearly 300, What are you doing with your scaling?
I get what you are saying now....so just for you I will scale the graph the "Shiv" way
Old Nov 12, 2004 | 12:50 PM
  #36
gsujeff55's Avatar
lol, nice smushed graph. virtually NO lag. HAH
Old Nov 12, 2004 | 01:58 PM
  #37
Aby@MIL.SPEC's Avatar
what octane was used?
Old Nov 12, 2004 | 02:08 PM
  #38
Dyno4mance's Avatar
93 oct unleaded
Old Dec 25, 2004 | 08:34 PM
  #39
sleet's Avatar
Very nice graph
Old Dec 26, 2004 | 12:03 AM
  #40
S54M3's Avatar
I am about to install a set of 264/264 and let it tune by Shiv, but is that a good combo Set? what's the HP range going to be with that set of Cam Gears, and what should I set the timing to on the Cam Gears?
Old Dec 26, 2004 | 04:58 AM
  #41
Toddevo 8's Avatar
gsujeff55, I can tell you from what I have seen. If you dont kno0w what you are doing on the cam install ,let Andrew do it for you . It may cost you gas money but it can save your engine. I had some one else do it the wrong way and cost me big money to fix.
dont do this at home.
my2cents
Old Dec 26, 2004 | 06:04 AM
  #42
Toddevo 8's Avatar
I also have the 272 cam on both sides and the idle is fine. most dont know that I have cams.
Old Dec 26, 2004 | 08:21 AM
  #43
kapolani's Avatar
Originally Posted by EidolaDream
Dyno4mance and vishnu, need I say more?
I say that because my father just got his dyno graphs in and I must say im speechless to say the least, he got some really nice numbers on nearly stock boost. Look at the graphs below. At first Shiv wasnt able to flash his ecu due to the fact that the factory had flashed it already so Andrew at Dyno4mance had to make due with the limited boost. I think the graphs speak a thousand words on there own. It’s amazing what a good tune will do for a car. MODS = Vishnu stage 1 sig ++
So with this my father and I both say thank you Andrew and Vishnu crew for all the help and support.
Oh and Andrew get rdy because I’m going to be bringing my MR in as soon as I get the goods from the Vishnu guys DUN DUN DUN!!!! When this takes place I don’t know but hopefully sooner than later lol.
Nice numbers!
I love the nice power band.
Most IMPORTANTLY I love the AFR's!
Awesome work!
Old Dec 26, 2004 | 12:25 PM
  #44
shiv@vishnu's Avatar
Those crazy limeys can tune!
shiv
Old Dec 26, 2004 | 06:03 PM
  #45
Dyno4mance's Avatar
Thanks for the kind words guys but the Xede is really the star in this case...
I really think it caters for what 90% of evo owners here in the states really want from an engine management sytem....Far better for a daily driver than some fussy and complex stand alones with no pre-set idiot protection
My 2c
