Stage 1 signature problem?
Any help please!
I have stage 1 signature and I don't think that the car is performing as it should be. I ran with a friend's stock Evo and in the first two gears he was in front of me, in the third gear I began to get closer but not with the power that I thought it would be. I notice that he's car boosts a lot faster than mine. We ran a few times and he's car was always ahead in the lower gears. What can I do to check if the settings are correct?
From: RAMAR village, pampanga PHILIPPINES, Temecula, CA
not all cars come out of the assembly line with the same amount of hp and torque. maybe his car has more hp/trq than yours had .did you have it dyno'd before and after the install?
What's your last name? I'll check the records to see what map was loaded into your XEDE or XFlash. Also, who installed your cam gears? Did they line it up with the tooth with the red dot (as opposed to the zero mark)?
Shiv
Shiv
