boost table
Old Nov 28, 2004 | 08:59 PM
smackmatic's Avatar
boost table
What would happen if I turned every cell on the boost table to 100? Could this damage my car?
Old Nov 29, 2004 | 06:57 PM
smackmatic's Avatar
Cant anyone help me with this?
Old Nov 29, 2004 | 07:00 PM
n00dle's Avatar
It's akin to tuning an MBC to give you more boost.
Putting 100's in cells will raise the boost in the specified cell load sites and may cause an overboost situation. Depending on the type of fuel you're running you may not want that and risk damage.
Old Nov 29, 2004 | 07:25 PM
shiv@vishnu's Avatar
In most of our stages, the duty cycle table is already near or already set to 100%. It just works out that way. So raising it from say 96% to 100% isn't going to have a noticeable impact on boost level. Especially above 5500rpm where the turbos start their natural boos taper (compressor limited). The area most sensitive to small boost table changes is at full throttle in the 3000-4000rpm range where boost can spike if dialed in too aggressively.
Shiv
Old Nov 30, 2004 | 04:44 AM
smackmatic's Avatar
Thanks guys
