Weird noise under Stock Air Box? (Xede)
Old Nov 29, 2004 | 07:35 PM
snoop's Avatar
I have weird sputtering noise near the stock airbox. I remove stock airbox and remove boost soleniod and the problem went away. Also checked boost lines and they are fine. Car drives good with boost hitting 21-22 than tapering to 18 at redline on 91. I have stage 1 with Xede.
Has anyone heard this noise or know what it could be?
Old Nov 29, 2004 | 08:49 PM
Jaylenospoolboy's Avatar
You need to tune your radio to a station.......
Sorry, couldn't resist.
Check your intercooler/intercooler tubes. They might have a small leak but still hold boost.
Reminds me of the thread from the guy in Germany who had a rodent chew through the silicone intercooler tube.......
Old Nov 29, 2004 | 08:56 PM
alfredob1's Avatar
For the record we did not remove it but just unplugged it. He started his car and it stopped making noises. We plugged it back in and it started making noises again. I also checked the hoses connected to the solenoid and they looked fine (not broken/torn). Any more input?
Old Nov 30, 2004 | 09:21 AM
snoop's Avatar
Shiv, Smoggy, Andrew, Nick, Dave?
Any help would be great.
Old Nov 30, 2004 | 09:29 AM
Jorge T's Avatar
You may have a bad boost solenoid? Swap it out with a borrowed one and see if it still does it.
Old Nov 30, 2004 | 10:08 AM
snoop's Avatar
That is what I was thinking but the car runs great and boost works like a charm. If the Solenoid is bad then why is my car running great and holding boost correctly?
Old Nov 30, 2004 | 10:14 AM
ice-slidin-fool's Avatar
I've had this one... Be sure your boost duty is set at 100% across the lowest row in the Xede graph. This should fix the clicking noise...
Old Nov 30, 2004 | 10:38 AM
Nick@Vishnu's Avatar
Try this for me.
With Xmap, go to the boost table. In the bottom two rows of the boost table, change the 100s to zeros.
If the clicking stops, chances are you just have a noisey boost solenoid. Its not an uncommon problem on evos.
Dustin-
Old Nov 30, 2004 | 11:02 AM
snoop's Avatar
Originally Posted by Nick@Vishnu
Try this for me.
Dustin-
Thanks I will do that today
Old Dec 1, 2004 | 06:28 PM
Hammerr's Avatar
Yeah took me a while to figure this one out too. You only need to have the bottom row of the boost table to be zero's.
Old Dec 2, 2004 | 09:53 AM
You'll need to know if you're using an "absolute" or "intercept" model for boost control. If the numbers on the "unknown" graph are around 90% to 100% then you're using the former and the bottom row should be at 100%. If the numbers in the graph are smaller (5%-20%) then you are using the latter and the bottom row should be set at 0%.
Following this rule will keep the solenoid from having to work (click) during idle.
Good luck!
Old Dec 2, 2004 | 10:38 AM
snoop's Avatar
Good luck!
You are correct since I flipped the switch to my 93 map and no clicking. I have to fix my current 91 map Thanks for the help
Old Dec 2, 2004 | 12:53 PM
Noize's Avatar
EvoM Administrator
Cool; glad to hear this had a happy ending!
Struc
Mar 21, 2015 10:59 AM
bimmer777
Aug 11, 2014 09:43 AM
Mr. Stock
16
Oct 27, 2010 07:09 PM
jrsimon27
69
Oct 22, 2007 01:42 PM
