10.5 hot side charts
Old Dec 14, 2004 | 01:56 PM
absinthe's Avatar
I searched for some graphs that were resonably close to the following but could not find them, could someone send them to or post them for me.
Evo:
Stock turbo
10.5
turbo back (woth or with out O2)
feul pump
exede or xflash
Old Dec 15, 2004 | 11:52 AM
meanmud's Avatar
They're out there - search a little better
Probably will not find the 10.5 Hotside upgrade without cams and other assorted goodies
Old Dec 15, 2004 | 11:54 AM
absinthe's Avatar
I searched using just 10.5 and couldnt find them, can anyone else help
Old Dec 15, 2004 | 11:56 AM
Terry S's Avatar
I think smoggie had a chart of his 10.5 with just stage 1+.. however, I think his current chart is with additional assorted goodies though.
Old Dec 15, 2004 | 11:57 AM
Ludikraut's Avatar
Here's Smoggy's thread ... dynojet numbers on a stage 1+ w/ 10.5 hotside: https://www.evolutionm.net/forums/sh...d.php?t=112997
try searching for stage 1++ or 1+++ ... there are a couple of threads here on the Vishnu forums talking about them. Dyno4mance's website may also have a few dyno charts posted of 10.5 setups...
l8r)
Old Dec 15, 2004 | 12:01 PM
Aby@MIL.SPEC's Avatar
Dave-
Read the bottom post by shiv. I have yet to see a direct turbine compare, let alone on 91 octane for which I am most interested in.
hope this sheds a little light:https://www.evolutionm.net/forums/sh...d.php?t=104203
Old Dec 15, 2004 | 12:04 PM
absinthe's Avatar
It was my impression he had the TME turbo in his car not just 10.5
Old Dec 15, 2004 | 12:09 PM
Terry S's Avatar
Well the TME is basically just a 10.5 hotside with a Ti turbine wheel. the Ti wheel wont add power, it makes spoolup a little better so its results should be pretty similar..
Wait a minute, what about that car from Tuner Transformation? Wasn't that a 1+ with a 10.5 hotside only?
Old Dec 15, 2004 | 12:11 PM
VTECH8TR's Avatar
Yes it also had the 10.5T side as well.
Old Dec 15, 2004 | 12:15 PM
erikgj's Avatar
The real TME has a smaller compressor wheel also. 1+ are usually with cams. I think Dyno4Performance had the most straightforward before and after dyno runs on the 10.5 Hotside.
Old Dec 15, 2004 | 12:16 PM
Terry S's Avatar
Arent they both 16g compressors though (usdm 8 and TME)?
Old Dec 15, 2004 | 01:45 PM
jamevo8's Avatar
If anyones interested Im selling my evo from Tuner Transformation, $24000. need cash asap must sell fast!!!! pm me if interested
Old Dec 15, 2004 | 01:53 PM
TampaTurbo's Avatar
Why are you selling it? Your famous now man. You kind of go with the car.
Old Dec 15, 2004 | 02:55 PM
559EVO's Avatar
So whats the spool/hp difference between a TME turbo with the 10.5 and a stock turbo with the 10.5 housing?
