Xede reliability
Old Dec 21, 2004 | 10:39 AM
ruzs's Avatar
Xede reliability
My Xede keeps crapping out on me and it is getting more frequent. I will start the car and the maps won't load. I have to stop, turn the car off , turn the ignition on, wait a few seconds and then start the car again. Talk about a pain in the ***. I sent an e-mail to Vishnu, but I have not received an answer yet. What's up with that.......
Sigfrid
Old Dec 21, 2004 | 10:42 AM
Dyno4mance's Avatar
did you get the resistor modified inside the Xede yet?
If not they have a fix for the problem you describe
Try them on the phone
Regards
Old Dec 21, 2004 | 10:55 AM
ruzs's Avatar
Xede
Thanks Andrew. I appreciate your help.
Old Dec 21, 2004 | 11:30 AM
evolute's Avatar
please keep us updated ruzs - i'm looking at getting the XEDE and i like to see how long it takes to get problems like your's fixed.
thanks!
Old Dec 21, 2004 | 11:34 AM
shiv@vishnu's Avatar
Sigfrid
Have you tried using another XEDE? Maybe from a friend if someone nearby has one. The reason I ask is that your car had some installation issues with respect to the CAS, IIRC. And the CAS sensor is critical to XEDE functionality. Without a stable CAS input, the XEDE will go off-line. I've seen this once before with someone on the east coast. Trying different XEDEs didn't solve the problem.
Shiv
Old Dec 21, 2004 | 06:32 PM
Jorge T's Avatar
Check the ground wire crimp on connector. On mine the crimp was loose, would turn off and do all crazy stuff. A good squeeze with a crimp tool fixed it. I also sanded the Mitsu metal where I screwed the ground wire and it won't do that anymore.
