XEDE 11psi !
Old Jan 4, 2005 | 09:18 AM
MITSU16G's Avatar
XEDE 11psi !
When i wire the boost through the XEDE iam only running 11psi and it is only restrictive through the xede , when i wire back to the stock ecu iam runnin the stock 19 psi whats goin on here ?
Old Jan 4, 2005 | 09:29 AM
Eric Lyublinsky's Avatar
From the Xede to the factory harness does not sound like it's hooked up check there fist
Old Jan 4, 2005 | 09:40 AM
jj_008's Avatar
Make sure you have a map loaded into the XEDE.
Old Jan 4, 2005 | 09:52 AM
Dyno4mance's Avatar
00000000's in the xede table...load a map you be fine
Did you check the green boost wire was correct?
Old Jan 6, 2005 | 08:54 AM
snoop's Avatar
Same thing happen to me and I reloaded the map and it worked
