Should i be worried
Should i be worried
Today i was running low on gas so i stopped to fill up at a station. I didnt see the order of the pump readins so i filled up with 89 octane instead. :[ i was in 5th gear today at about 3k rpms and it felt like i had no power. after that i drove straight to the pump and filled with 100 octane. Should i be worried?? Im running a stage 1
Ya Torco do significantly raise yr octane unlike those octane booster that raise up to 7 pts ( 0.7)
OR u can go to the any Home Depot or paint supply store and get some 5 gallon Toulene( 113 oct) or Xylene( 117 oct)
If you are worried, most of the time severe detonation will kill a spark plug too. Pull them out and check them. If they are that bad you would have one cylinder not firing so you would know. I am sure you are fine but it never hurts to take a look at them to ease the mind.
