Question about xede Stage 1 93 oct. base map.
Old Feb 22, 2005 | 06:37 AM
modvp's Avatar
Will this map be too aggressive on a complete 3 inch exhaust system [3 inch dp, -testpipe (ie. no cats), and -exhaust (93 octane)]?
Old Feb 22, 2005 | 08:28 PM
gsujeff55's Avatar
no
Old Feb 25, 2005 | 05:08 AM
modvp's Avatar
Thanks, I think I found a partial answer to my question:
Originally Posted by shiv@vishnu
Hi Morris-- Try uploaded the Stg 1 93oct map from the website. I know you don't have cam gears but it is worth trying. I've seen that map work well in Stg 0+ cars as well. As for boost pressure, 21-22psi of peak boost is fine. That is, that boost pressure is only reached for a moment and then it falls off to ~20psi and then tapers off to ~18psi by redline. If you want to, you can reduce peak boost pressures by simply lowering the appropriate numbers in your boost table.
Shiv
https://www.evolutionm.net/forums/sh...highlight=xmap
