Just plugged in an Xede, do I need a fuel pump?
Originally Posted by evoate
I don't think you should be running 24 lbs of boost though, unless your using alky or race gas. Was the xede set to this when you got it? Maybe you're boost gauge is reading wrong.
I overran the pump with just a stage 0+ setup. It doesn't happen right away... after about 15 laps my EGTs started getting uncomfortably high. I think it was the same problem Shiv experienced after many dyno runs.
Fuel pump is a good idea. Cheap insurance
