Cel po340 po335
Cel po340 po335
My car just throw these two codes, something about the crankshaft positions sensor A circuit. Can someone tell me what's going on??? Thanks in advance...
Lopey idle, the occassional stall (maybe 5 in the three months I was driving around thinking ... "just need a tune") and only threw the two codes (same to codes) once, about 5 hours after picking my Evo up from the shop.
Bottom line is you have to pay attention to the installation of the cam gears ... if you've got the Vishnu cam gears and your gas mileage bites the big green weenie, you've probably got an install problem on the gears. There were two Evos this weekend with same lobey idle, same gas mileage problem, and Vishnu cam gear installation problems.
br,
dave
Last edited by raymerd; Mar 21, 2005 at 04:25 PM. Reason: I can't spell, I learned to read phonetically
Thanks for your replies, I've the stage 1+ for 10k already, never throw these two code before. I had problem starting my car due to low battery (mini battery). After I charged up the battery and get the car started that's when it throws the codes. I cleared the codes and it hasn't come back so far. Hope this is a one time thing...
Does your V3 Xede changed the car's startup, I mean it crank a little different...
Originally Posted by evo55
Had mine when Vishnu installed the HKS cams and gears. I reset it using the OBD scanner. I increased the idle. It has not come back and seems to be OK now. I also have the V3 for Xede.
Yes it cranked a little differently compared to the XFLASH stage zero plus, which is the stage I was before. Every morning it starts up with no problems. I can hear the fuel pump humming also. I noticed that it will stall only if you are at stop and try to steer all the way (left or right). It seems like losing the vaccum and the idle. I already have increased the idle by adjusting the idle screw. I also notice the stalling, with all the conditions above, happens when the wheather is hot. Right now it's been raining here in the bay area and so far I have not stalled.
