Exede Boost line Q
Old Apr 1, 2005 | 01:06 AM
Kec's Avatar
Kec
Exede Boost line Q
Hi guys I used to have a manual boost controller before the Exede and my question for Shiv and all you guys with the Exede knowledge I only have a stock boost line from the factory boost solenoid and no other two so can I use the MBC boost line with the exede or do I have too purchase the other two lines from the turbo and from the Westgate to the T fitting so any advise is appreciated thanks .
Old Apr 1, 2005 | 05:28 AM
Dyno4mance's Avatar
It would be best to order a new set of lines from Mitsu as they have more than the one pill you remove in them....
If you use the MBC lines your wastegate will open prematurely and you will not achieve any boost
My 2c
Old Apr 1, 2005 | 09:44 AM
Kec's Avatar
Kec
My 2c
Yes I have the other line with the boost pill .
Old Apr 1, 2005 | 11:05 AM
Volunteer's Avatar
My 2c
Thats what I did $32 dollars for factory setup clamps, pills and all. Much easier than trying to get all the pills back in place, geting the right lenghts.
Old Apr 1, 2005 | 01:27 PM
Kec's Avatar
Kec
I just ordered the set and it was $23 do you have a part number for your set ?
Old Apr 1, 2005 | 01:59 PM
jfh's Avatar
jfh
My 2c
Andrew,
How many pills are in the stock lines for an 03 Evo? I removed one per Vishnu Xede installation instructions and was not aware that there were more.
Old Apr 1, 2005 | 02:11 PM
Volunteer's Avatar
Sorry, that was a year or so ago. I could make a call Monday to a friend at the dealership to get the part# for you. There is two boost pills one at the bottom of the line and the one at the top near the boost solonoid (The one you take out for the Xede). There is also one inline where it T's to the wastegate I believe.
Old Apr 1, 2005 | 06:45 PM
Kec's Avatar
Kec
Thanks man I think that I ordered the right parts , you can not purchase a one or two hoses separate they sell it only in sets .
Old Apr 1, 2005 | 08:23 PM
Volunteer's Avatar
Thats correct. Good luck.
SR20DE-T
Jun 17, 2006 09:33 AM
Emo-Evo
24
Sep 28, 2005 03:42 PM
tom@kartboy
33
Oct 7, 2003 02:53 PM
wilson1
Sep 23, 2003 11:13 PM
