Omori gauges warning set-up
Old Apr 7, 2005 | 08:09 PM
Evo23IG's Avatar
I have finally finished my install of my Omori boost, oil pressure and EGT gauges. What warning levels should I set up for my oil pressure and EGT guages? And what are some normal levels oil pressure and EGT readings? Thanks in advance.
Old Apr 7, 2005 | 08:22 PM
SilverCOEvo's Avatar
oil pressure runs pretty high...I can't recall what mine ran in my 03...but i'd guess a warning a little above 100 would be good. The egt is in C or F? I think about 1650F would be a warning level as well if I recall the posts correctly. I was regularly over 1500F...
