map switching
Old Apr 11, 2005 | 06:26 PM
SuPeRNeT's Avatar
map switching
how do you save maps to a differnt switch setting?
Old Apr 11, 2005 | 06:44 PM
rlazer5000's Avatar
I think this thread should go under the XEDE category in EVO tuning. Sorry, i dont actually know the answer to ur question, but shouldnt it say in ur instruction manual? If not, just use the search button, or look under the XEDE section. Good luck!
Old Apr 11, 2005 | 06:52 PM
Dustin@Vishnu's Avatar
In order to save a 2nd map (map bank 1) connect the wires together, and turn the ignition to ON. At this point, you need to make sure on X-map that map bank 1 is the bank online. If it is, then select the map you want in that bank, and upload it just like you normally would.
Let me know if you need any more help.
