HELP! Vishnu Cam Gear Install?
Old Apr 23, 2005 | 02:53 PM
revolagoy's Avatar
Guys I need your help. I have installed my Stage 1 vishnu cam gears and have a question. I am trying to check to see if the crankshaft is in time with the cams. When I set the cam gears to the valve cover marks(red dot on vishnu gears) the white mark on the crankshaft pulley ends up to the far right on the scale. From left to right it reads BTDC, 10 then what looks like a plus sign. My crankshaft pulley is lined up with the PLUS sign mark to the far right. It's the last mark on the scale to line up the crankshaft pulley. Is this correct???
Old Apr 23, 2005 | 04:00 PM
Dyno4mance's Avatar
you are bang on sir...now button it up and drive it
Old Apr 23, 2005 | 09:23 PM
revolagoy's Avatar
Thanks!
