Why I hate XEDE software, and essay by EvoSam and a call for help
Old May 4, 2005 | 07:36 AM
Ludikraut's Avatar
EvoSam, do you have the Thinkpad software installed? Usually you can activate/deactivate ports within the Thinkpad utilities. If you don't have it, you can probably download it from IBM.
l8r)
Old May 4, 2005 | 08:23 AM
snoop's Avatar
EVOsam if you have friend that has a laptop you should borrow it. Than donate your POS laptop to charity
Old May 4, 2005 | 09:23 AM
Ninj0x's Avatar
Originally Posted by EvoSam
Don't have the processor speed for XP, already considered that.
I'm running XP on a 233Mhz dell laptop... XP requirements are lower than you think. All you have to do is get rid of all the pretty GUIs.
sr20det91's Avatar
Any luck with it yet evosam??
donour's Avatar
I went to use the Xupdate software and it wouldn't start up because there was no default printer for the machine.
I have already reported this bug to shiv and the orginial developers at chiptorque in australia.
There's an easy fix though. Download the adobe postscript printer driver. It doesn't require any hardware or any funky fooling of the com ports. It's kind of like a "virtual printer".
http://www.adobe.com/support/downloa...atform=Windows
IMHO, the real problem is that it has to run on windows in the first place.
Chiptorque and Vishnu: Release the source to the communication protocol! Let us build a cross platform mapping and updating tool!
d
Old May 4, 2005 | 09:31 AM
crusin_lancer's Avatar
I agree I am running XP on a P2 333mhz dell desktop. Just set the tab for better performance. Thing runs like a champ.
Old May 4, 2005 | 09:36 AM
EvoSam's Avatar
You are assuming that the machine is running 233Mhz or better....it's not. More like 133Mhz IIRC. I just got into work and haven't tried again yet as I have to do some actual work for a while. I'll check out the Adobe solution and see if IBM has drivers on their site for this machine.
Thanks,
Sam
Old May 4, 2005 | 09:39 AM
EvoSam's Avatar
Oh, as for the port confilct, COM1 is associated with the IR port. I don't use it nor do I have any idea why I would need to but removing or disabling it won't rename the other one from COM2. I don't think the printer is conflicting with it at all as I doubt it uses IR.
Sam
Old May 4, 2005 | 10:18 AM
donour's Avatar
Yeah, even with other serial ports disabled I'm pretty sure the bios is going to map the onboard RS232 port to the same COM number regardless if what you do. As Ludi said, tryin downloading the IBM thinkpad utility. That _might_ allow you to remap the ports in software.
d
EDIT: Hell, your in redmond. Walk over to the microsoft campus and start yelling at device driver engineers.
Old May 4, 2005 | 10:40 AM
EvoSam's Avatar
Originally Posted by donour
EDIT: Hell, your in redmond. Walk over to the microsoft campus and start yelling at people device driver engineers.
The thought has seriously crossed my mind, it is walking distance from me now. But, you have any idea what the security is like there? Pretty intimidating. There's a police station annex on the campus.
I'll give the utility a shot, but I did source a machine today that only has one COM port so it should work. The pressure is off though as the track day was called due to weather.
Sam
Old May 4, 2005 | 10:46 AM
donour's Avatar
Offtopic, but you might find this one amusing. I interviewed there a while ago when I was graduating from college. For the couple of days I was there, they gave me a visitor's badge with one of those magnetic stripe thingys. I wasn't that interested in the job, so I made sure to try it on every single locked door I could find. They were NOT amused.
d
Old May 4, 2005 | 11:02 AM
jman425's Avatar
Sam
maybe because they pay 90% of redmond's taxes ?
Old May 4, 2005 | 11:07 AM
shiv@vishnu's Avatar
Out of all the programmable ECU software I've ever tried, XMAP is by far the most easy to communicate with. Quite literally, ALL the communication problems I've seen or heard of have been solved by simply trying another laptop.
my 2c
shiv
Old May 4, 2005 | 11:15 AM
Ludikraut's Avatar
my 2c
shiv
Sounding a little like Bill Gates there ... "if the software doesn't work, all you have to do is upgrade the hardware..."
Watch out folks ... we have a Shiv Gates in the making.
l8r)
Old May 4, 2005 | 11:34 AM
lowkey's Avatar
Registered User
When you install a printer, you could also use the “print to file” option. That way you don’t use a real serial, parallel or USB port on you computer.
