Injector Scaling in XEDE
Old Jun 26, 2005 | 12:09 PM
Zarathustra's Avatar
I will be installing 660cc injectors on Monday or Tuesday. I have read the XEDE can scale correctly for larger injectors without having the unit sent back to Vishnu. In Xmap3 (yes I have a v3 firmware) there is a Injector Scaling button that brings up Output Scale Factors. Obviously Freq0 is the only one that concerns me here, but I'm not sure what I should enter. 660cc injectors are 20% larger than stock, so would I set Freq0 to 83%? Any ideas?
Old Jun 26, 2005 | 12:12 PM
I forgot to add that I have a White Rabbit in. Being a larger turbo, I'd assume it would lean out the AFR. Considering how rich Evos run stock (like 9:1), would it be safe to just run the timing and fuel tables zeroed out hoping the leaning from the bigger turbo wouldn't lean the stock AFR too much?
Old Jun 27, 2005 | 09:28 AM
shiv@vishnu's Avatar
I dont recommend using the MAF scaling feature to adjust for the larger injectors. It induces too much passive timing advance which can be a ***** to tune out if you dont have a high resolution dyno to pick out all the points of knock retard. Much better to get your ECU flashed for the larger injectors. We have an XEDEflash for the injectors you are using.
Shiv
Old Jun 27, 2005 | 10:08 AM
Yeah I understand that, but I don't have the time to send out my ECU and I already have a previous XEDEflash The car will be tuned on a Mustang.
Old Jun 27, 2005 | 10:17 AM
Since you already have an XEDEFlash we'll be happy to reflash your ECU for the larger injectors free-of-charge. I reeeaaally recommend it. So much that I suggest you postpone your dyno appointment.
shiv
Old Jun 27, 2005 | 10:51 AM
*sigh*
Sent you a PM
Old Jun 27, 2005 | 08:13 PM
gsujeff55's Avatar
Off topic...where ist he EXACT writeup on converting to v3? My car is down right now so now is a good time for me to mess with it.
Please, someone show me the light. I already have the wire.
Old Jun 27, 2005 | 10:02 PM
Sackett's Avatar
soo a flash is always needed (recommended?) with larger injectors? the xede alone cannot compensate?
Old Jun 28, 2005 | 01:44 PM
gsujeff55: do a search in this forum, there are a few threads on it
Sackett: the XEDE can scale for larger injectors on its own, but Shiv high recommends against it.
Old Jun 28, 2005 | 01:50 PM
Erik@MIL.SPEC's Avatar
Shiv,
Can the XEDEflash be done for '05s at the SoCal dyno day? Thanks. I have Smoggie's old AMS 680's.
