Getting SMART with Methanol
Old Jul 9, 2005 | 06:06 PM
shiv@vishnu's Avatar
Exclamation Getting SMART with Methanol
Just finished tuning Turbo Magazine's Project EVO. It is running a SMART XEDE with what is essentially a Stg 1+. It is a 2003 car with the smaller hotside. It also has the stock IC. Still, on 91oct, it made a repeatable 290-295whp.
However, with Methanol injection activated, it made 362whp. The Meth injection is being controlled by the XEDE (which, in essence, is generating a pseudo-MAP signal). But unlike a real MAP sensor, the 0-5v signal is fully 3D mappable as a function of MAF and RPM. It allowed me to be more agressive at higher load/higher RPM without overfueling the engine with meth at lower engine speeds/loads. I'll post up the super SMART maps later this weekend. Along with new associated SMART beta XMAP software
And there will be a $100 credit to the first person to figure out the "logic flow chart" just by looking at the maps. Each map has 7-8 tables. These tables are titled:
Fuel
Timing
SMART Fuel
SMART Timing
SMART Fuel Thresholds
SMART Timing Thresholds
SMART Boost
Methanol Control
Wont be able to figure anything out yet. Need to wait until I post up the maps
Cheers,
Shiv
Old Jul 9, 2005 | 06:11 PM
kmcconn9's Avatar
good to see more quality numbers out of the methanol
Old Jul 9, 2005 | 06:15 PM
Vishnu_Evo8's Avatar
damn... thats like 30 more whp than i made on race gas with a hotside... This sounds like the ultimate bang for the buck mod. What meth kit was in the car?
Old Jul 9, 2005 | 08:48 PM
leif's Avatar
ah yes, we were talking about this while dustin was trying on women's jeans at nordstroms today.... good #s for sure.
Old Jul 9, 2005 | 08:49 PM
dustin, or should i say strong bad looks like a size 0. Doesnt he?
Old Jul 9, 2005 | 09:11 PM
leif's Avatar
thats wut i said... lol.
i thought his name was muscles?
Old Jul 9, 2005 | 10:33 PM
donour's Avatar
Whoanilly. Where, may I ask -- about the same RPM?
I'm still a little awe-stricken that it actually works.
Fuel
Timing
SMART Fuel
SMART Timing
SMART Boost
Methanol Control
Cheers,
Shiv
Maps'ses? we don't need no stinkin' Maps'ses. Lemme give it a try without seeing the software:
FUEL
Fuel signal (wideband _and_ MAF) -> Xede Input - > read Fuel map point -> Get SMART -> Fuel threshold -> Adjust against fuel map -> Xede out [edit: ] oh i guess you could technically add injectors in there if those are now supported.
TIMING
CAS + buffered knock -> Xede input - > read cas map point -> Shop Smart, shop S-Mart -> Timing threshold -> adjust timing-> Xede out
BOOST
MAF + Tach -> xede input -> I am so smart, S-M-R-T -> calculate phantom MAP value -> adjust Boost output duty cycle.
METH:
Not really a diagram since there are no inputs. Effective octane is raised thus reducing knock activity and causing everything else to adjust more agressively. Well, not everything. If you want more boost, you still have to crank it up.
d
Old Jul 10, 2005 | 05:29 AM
EidolaDream's Avatar
holy crap, so is meth a better idea over c16? I mean from looking at the numbers, yes, yes it is. Good God Bazzle 362whp DD!!!!
I think I know something I need to add to my stage 3 kit!!!!
Old Jul 10, 2005 | 07:29 AM
jj_008's Avatar
Shiv, check your PM's. Maybe I can tell you in person
Old Jul 10, 2005 | 07:33 AM
Smogrunner's Avatar
362whp on a DD? Shiv must be lying. That is insane.
Old Jul 10, 2005 | 09:15 AM
gsujeff55's Avatar
EXACTLY what i was about to say.....is this on the VISHNU dyno???? DAMNIT MAN!
What meth kit were you using? If you can repeat this(or close) on andrew's dyno with the smart xede i just might be the happiest dood alive!
Damnit, now i gotta figure out how to come up with some money. Is this something that can be done with the "through the mail" SMART upgrade? I don't know if i, myself, am SMART enough to make that work.....
Old Jul 10, 2005 | 11:08 AM
Yes, it was on our DD dyno
Shiv
Old Jul 10, 2005 | 11:12 AM
newmr's Avatar
To repeat, which kit was it? SMC, Snow, Other?
Old Jul 10, 2005 | 11:21 AM
Oh sorry. It started off life as an AMS kit with a couple of changes to its drive/control system.
Shiv
Old Jul 10, 2005 | 11:28 AM
RREvo's Avatar
Shiv
So what Alky kit should we buy so that is compatible with the S.M.A.R.T ? and can you post a map for like stage 1+ with S.M.A.R.T and Alky so us that don't have access to a tuner shop can have a starting map for the S.M.A.R.T ?
